  • Replies 6k
Posted Images
nah guys... that track thing was a joke i baught it for work!!
i have just realised i now own the car i hate and the car i love. :(
i just cant help but think it is in really good condition and well maintained and it was just F****ed
for factory!!! :):):no:
lol, ok i was copying and pasting a thread i had made on ns.com onto here, and in that thread it has a few attachments in it, well when i pasted it in SAU and posted it, those attachments have certain numbers which link back to that site and post up the image that was uploaded onto that site at that number.
anyways the attachment numbers from my post on ns.com obviously link up to different attachments on this site, and this is what i came up with when i went to post it:
then i wrote in a few other numbers around that one and got:
Edited by nisskid
lol, it all went wrong. :laugh:
got the car up on jacks, rear wheels off; ready for new brake pads & braided lines..... 1st caliper nut, pull tight, cracked the nut seal & put my knuckles into the inner wheel arch. doh. 1st nut made me go to hospital, lol, 3 stitches to a knuckle joint as we could see -everything- inside.................. :unsure: she was preeeetttty open ! lol, used a scalpel to scrape the black undercarraige gunk out off the bone. bwahahahah !
oh well. will be interesting at work while i do everything lefthanded. got a months worth of work to get done by 26 october, kneeop date. man im such a retard sometimes :laugh:
Edited by Tangles
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
