  • Replies 6k
Posted Images
sorry to burst the bubble
dont forget the stamp duty + insurance :D
thanks for that.
but i do know theres more to purchasing a car then the for sale price...
the bubble remains unburst :(
Hey Jess :D
It is all good, i know you are busy it is all good.
No spotting with the plates yet as i am not putting them on until the new front bar gets fitted and painted and the rear number plate bracket gets fixed.
How is your car going?
Oh thats going to look good, so it that getting ready for autosalon? When is it on down there?
My car is going great, Getting use to driving it now and how it handles.. :(
Alot more confident in it and cant wait for our Trackday in July and DECA in August in Shepparton...Going to be wild!!!
My car is going great, Getting use to driving it now and how it handles.. :cheers:
I will send you pictures i a couple of weeks when it is fitted and painted, it is going to look really good.
Not sure whether i should mesh or not yet??
Good to hear that you are enjoying the GTR, i so hope that we can havea drag track in Adelaide soon.
So want to put the 34 down the Quarter. :(
Your email isnt working, It sent one yesturday and it bounced back :cheers:
Yes definatly send pics!!!
Hmm mesh :cheers:
I have mesh on my front bar! I think it def a good idea because of the rocks n stuff that flick up from other peoples cars, just look at the stone chips you end up with on your paint! My mesh is black so it doesnt stand out like dogs balls!
yer whos got money on here, mayb we can all chip in a bit of money and buy a property and set up our own drag track. we would make our money back in no time hiring it out to other clubs! :cheers:
Edited by Adz2332
yer whos got money on here, mayb we can all chip in a bit of money and buy a property and set up our own drag track. we would make our money back in no time hiring it out to other clubs! :(
Ahhh to dream!!
You don't think SMASA and all the other drag associated clubs hadn't looked into this option? Or even the ppl trying to purchase AIR?? unless you got a few hundred million laying around, don't hold your breath :cheers:
Last I heard, its still in the courts over issues in the contract for purchase between Bob and JaneBill Russo (of City Dismantlers). It has been decided and appealed a number of times, however currently BOB still owns it. I think they have finally got some people working back at the track now for Drift practice, BUT the drags require a full re-fit of the lights/timing system and a re-surface. however I think its unlikely Bob will spend the money considering he still may lose the court battle.
We wait some more :)
Edit: Found the link http://www.nissansilvia.com/forums/index.p...howtopic=226071
Edited by Hotwire
Would you guys travel interstate to do an event ?
Track or drag day may result in breakages. :)
At least if I break something at Mallala I can grab the Landcruiser, hire a car trailer and tow the car back.
It would be awesome though and I still may look in to it in the future. I'd love to hoon around the track sitting up Brisby's (Troy alias Roy) arse to zip past on the straights. ;)
lol Brisby (Roy) has some good experience under his belt; I doubt I'd keep up with him. :)
The Riverland Motorsport Group are preparing a new track up here. That have the land and stuff already..... On there web site they say:
Where is the track at the moment?
EPA Tests have been carried out and approved.
Native vegetation was consulted and approval given to clear the runoff area.
Local Council has given approval for the Complex.
Soil tests have been done ready for the ground preparation.
All plans for the Complex have been drawn up.
Pit area fence has been extended 50 meters to allow for permanent pit shedding.
Return Road base has been laid down along the pit fence.
The concrete barrier blocks are on site ready for placement
So cant be 2 far away??
www.riverlandmotorsportclub.com.au
Just my 2 cents
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
