  • Replies 6k
Posted Images
$300 for splitfire erm were they off the back of a truck :laugh: really that is very cheap and sounds too good to be true and well we all know the saying
but do hope all works out well
Where they second hand???
Hope it works out for you Dan, really frustrating when this sort of stuff happens :laugh:
Yer haven't been on the computer all that much lately. Just jump on for a sec here and there to whore sau and thats pretty much it.
OMFG.. Your actually online and visible now Madaz. Not cloaked. :P
Oh yer. I can't weld for shit. If there's the slightest gap I blow holes. So tack weld and off to the exhaust shop for a quick weld. AAA said it should take them 30mins to 1hr max so at most $60. Sounds like a plan. $$ and parts etc has held me back a tad from getting it on the road quicker; but next week is the week. (As I keep saying)
The dump is super easy every thing lines up with the front pipe perfectly using a single 3" 90degree bend. The wastegate is a tad trickier but I'm getting there. I bought a cheapo Carbide bit from ebay which broke within the first 30secs of port matching the flange/spacer. As they say; Poor/tight man pays twice. :stupid:
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
