thanks Jess
have you had a chance to look around @ 5 stud hubs
i found a topic but cant find it quickly here basiacally some guy selling front struts to stagea with
R34 fron rotors and calipers and rear 33 gtst hubs and calipers
ive got my front rotors and calipers will talk to a guy about getting his rear end rotors calipers and hubs
then to my knowledge all i need is front hubs to suit ATTESSA
Yeah I did and I can get them but the GTR 5 stub hub will only fit on the front
so looking at another option for you and will get back to you asap
sorry just so dam busy at the moment have no time to post at night
  • Replies 6k
Posted Images
yeah that is fine as i said i will be getting GTSt ones here locally
its the front that gets tricky, do GTR hubs suit GTS4 axels this needs to be confirmed
well got my new clutch in my car....
xtreme 6 puk ceramic button with 1600kg pressure plate, chromoly lightened flywheel.
The best single they make, its a right royal pain in traffic as its either stall it or chirp as you take off, but its an awesome clutch with the lightened flywheel the thing revs so so quick
cheers madaz. Saw the pics last night, was too tired to reply - but they arent showing up now?
Weird seeing my car in different colours lol but i stuck with the first one u did (original colour :D ) Thanx!
There Back up you must of just caught it @ a bad time :rolleyes:
very quiet he must have the flu1
anyways flick got down a couple of variations see what you think
yeah some brakes parts are on ebay from a stagea.....
Have you got a Link Brendan
nope....the pamphlet states......
Maximum performance,
minumum driveability, apparently its the one all the top drifters are using
gunna start drifty'rosa now :(
Jess >>Here<< is the thread with the parts for sale and what made me think stagea but i dont need the whole arm bit do i? i can use my original components and just bolt on new hubs yeah?
looking @ the most cost effective way of getting conversion dont so i can save up for new rims and hopefully get this upgrade before hell freezes over
If it's still a PITA in traffic, can I ask why you decided on a single and didn't bite the bullet on a multi plate?
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
