  • Replies 6k
Posted Images
Flick:
Sad to see it go, but houses are never going to get cheaper and the longer you leave it the worse it gets. BUT once you are in, as long as you can afford it, skyline it up again!! :D
Would you consider swapping rims with cash your way at all? If so, PM how much diff you would be looking for :P
Willl let u know.. atm im having second thoughts bout selling. I love my car, more than i should love a car lol. Its part of who i am.. and im making myself upset just thinking bout selling lol. So for now.. im going to think bout it for a while.. maybe hold onto her for another year ..
I feel that selling my car for example is like losing a limb, WAAAH. It might as well be :D Its never going to be easy!
But I too need to sell as I am looking into getting a place (whats worse, in PERTH! super expensive!) The only good thing about it is that the company that I'll be working for takes care of all legal costs, stamp duty bla bla upto $30k... for me!!! Thats an opportunity not to miss... especially for a poor uni student like me :)
I was on you tube looking up random stuff in australia and i cant belive YOUTUBE can let all the racist stuff on there. It's crazy they pick on all the car hoons on youtube but all the racist stuff is crazy WHAT IS AUSTRALIA comming 2. It might be old news but it hell shocked me
Hey, happy birthday Pauley!!!! so where we going for the SAU lunch next week to celebrate?? =P
oh and I know its a few hours early, but good luck with the operation Tangles!!!! hope it all goes well for you!
Edited by Fishpaste~
Hey all
anyone head down to that dyno day for nissan vs toyota me thinks toyota may have won due to lack of nissans :laugh:
i recon if you have to go barreling over small trees and shrubs and what not you would want to do it in this
The toyota turn out was a little poor.. :)
A heap of 70-low 100rwkw toyota's with one that cracked 160 something rwkw.
I picked up second spot with darren picking up first with a massive boost leak. rbmans had dropped boost to 12psi and Im certain mine is valve springs :( arg.. the joys. :laugh:
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
