  • Replies 6k
Posted Images
Yeh wtf is with that! Very very annoying ( waits another 120 secs )...............................................................................
..................................................... 60..............................................................................
.... 30..............................................................................
............Submit
Hippy, looks like I will be picking the car up today fingers crossed. So dump will be good to go:) Getting a tune done by John Keen at turbo tune on friday at 10am, just an intermediate tune until I can find the $ to fit cams, head gasket and exhaust cam gear:)
Hi Nizmo, I was originally from the west, you should like it over here. Weather is a bit cooler, but the people are really friendly - more than makes up for it:)
BTW .... Post Wench :D haha
what suspension did ya buy hippy?
I went to have my brake pads changed over the other day and they found tha tone of my brakelines had snapped in two but sat in such a way on the caliper that the fluid didnt leak that much etc ...... very lucky girl!! specially since some of the mischief i get up too .... no brakes wouldve been the end of me.
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
