  • Replies 6k
Posted Images
  • 5 months later...
  • 1 month later...
I thought this was really funny.
I hate hoax warnings, but this one is important.
Please send this to everyone on your e-mail list.
If a man comes to your front door and says he is conducting a survey and
asks you to show him your bum, do not show him your bum.
This is a scam; he only wants to see your bum.
I wish I'd gotten this yesterday.
I feel so stupid and cheap.
