EF Falcon takeoff
EF Falcon Revs
Maybe its just me but I reckon it sort of does high up in the revs.
They do share the same engine layout afterall. :P
I think its a pretty nice car being 12 years old and nearly stock except for the exhaust system. (I know the owner)
Edited by GTS_300_Coupe
EF Falcon takeoff
EF Falcon Revs
They do share the same engine layout afterall. :santa:
lol no way man
lol sound like youve got a bomb in your engine bay :P tick tick tick tick... sure its not a commodore? lol their v6s love to tick
Hahah yeah I think the lifters really need to be replaced!
I think its just wear and tear over time, not to mention excessive stress on the motor from floggin it all the time. :D
A bit like a WRX, Skylines are unique in all aspects... after like 5000 RPM's - the Skyline roars like a Godzilla - nothing else can come close.
well i dont know about that, im sure sure mr 599 GTB might have to say something about that....
hehe no but i know where your comming from, the induction noise and the sound of an Rb through a good exhuast sounds IMO the closest thing to a jet from the outside.
wtf?? a rex?? are you serious dude. no chance.
at a motorkana in town there was a natro r33, and it sounded heaps like a falcon.
at low rpm a magna with a sports exhaust and cannon sounds a bit like a skyline.
all the natro skylines i've heard sound like aussie fords, but none of the turbos.
Edited by mad082
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
