Winton National Circuit (3.0Km) Lap Records
OUTRIGHT: Christian Murchison Reynard July, 2000 1m14.5697s
RACING CARS:
Formula Holden Christian Murchison Reynard July, 2000 1m14.5697s
Formula Ford Jamie Whincup Van Diemen August, 2002 1m26.2188s
Formula Vee 1600cc Jason Kerr Sabre 05 May, 2005 1m36.7371s
Formula Vee 1200cc Nicholas Jones Sabre May, 2001 1m37.3358s
Formula Libre Brian Sampson Dallara February, 2000 1m23.6319s
Formula Two Paul Stephenson Dallara June, 1999 1m23.8310s
Formula Three Michael Caruso Dallara 301 Fiat September, 2003 1m17.4600s
TOURING CARS
V8 Supercars Jason Bright Commodore VX August, 2002 1m23.1514s
Super Touring Jim Richards Volvo August, 1998 1m25.3181s
Future Touring Ray Sidebottom Commodore VX October, 2001 1m31.4544s
SUPERTRUCKS Inky Tulloch Freightliner October, 2001 1m45.0925s
CO-Drivers Trucks Steve Coulter Isuzu SBR May, 2005 1m53.7336s
NATION’S CUP Paul Stokell Lamborghini Diablo G September, 2003 1m24.8430s
GT PERFORMANCE Bob Pearson Mazda RX7 Series 8 September, 2003 1m32.6533s
GT PRODUCTION John Bowe Ferrari Challenge August, 1998 1m29.1420s
V8 BRUTES Damien White Holden VY SS June, 2004 1m41.0480s
PORSCHE CUP Wayne Hennig Porsche August, 2002 1m28.3335s
COMMODORE W. Wakefiedl Commodore June, 1999 1m35.1286s
SUPER BIKES Shawn Giles Suzuki GSXR 750 May, 2000 1m23.733s
SPORTS SEDANS:
Over 2 Litre Tony Ricciardello Alfa GTV August, 2003 1m22.2930s
Under 2 Litre Ken Hastings Snr Toyota MR2 March, 2003 1m31.4735s
GROUP C Phill Kirkham Falcon XE October, 2005 1m31.3669s
HQ HOLDENS Neville Haley HQ Holden May 1998 1m43.8275s
SALOON CARS Tony Evangelou Ford Falcon EB May, 2001 1m38.6151s
V8 STOCK CARS Andrew Miedecke Chev Monte Carlo October, 2001 1m31.2853s
MARQUE SPORTS David Stevens Porsche May, 2005 1m26.6358s
APPENDIX J Ian G. Jones Torana XU1 July,1998 1m37.8448s
IMPROVED PRODUCTION Phil Morris Datsun July, 1998 1m34.3156s
AUSTIN HEALEY Rob Rowland Austin Healey November, 2001 1m43.8940s
DAEWOOS Ian Kegg Daewoo Lanos October, 2001 1m50.9913s
MITSUBISHI MIRAGE Matthew Coleman Mitsubishi Mirage July, 2000 1m37.8655s
Bridgestone from the Potenza family I belive. i see a fair few Porsches come in to my work with RE55S fitted for road and track.
well then...i like them...kinda partial to the Potenza family
so they are above the RE050
sweet
RellikZephyr
They are called Potenza S-03's and I can only get them for ~400 dollars a tyre in 235/40/18 and thats god damn Bridgestone wholesale prices!.
They stick to the road like all buggery in rain or dry tho, the best tyre wall and tread design I have ever seen.
Um, I think people are getting their wires crossed. The R compound Bridgestone tyre is the RE55. There are two compounds available in Australia - a hard & a soft. If you go to an ordinary Bridgestone shop you will probably get a blank look from the bloke behind the desk, so try the more motorsports orientated outfits.
  • 1 year later...
Another option for a good comprimise tyre is the Federal 595RS. Speak to President James as Federal are looking at giving SAUVIC members discounts on their tyres. He has some on his EVO now and they look pretty good.
http://www.federaltire.com/en/html/pdetail...line=1&ID=3
Anyone tried these Fedral's and did SAU ever snare a discount from them?
Any idea how they compare to the Hankook R-S2 for track work? Just they are a cheaper alternative to the RE55's.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
