Winton National Circuit (3.0Km) Lap Records
OUTRIGHT: Christian Murchison Reynard July, 2000 1m14.5697s
RACING CARS:
Formula Holden Christian Murchison Reynard July, 2000 1m14.5697s
Formula Ford Jamie Whincup Van Diemen August, 2002 1m26.2188s
Formula Vee 1600cc Jason Kerr Sabre 05 May, 2005 1m36.7371s
Formula Vee 1200cc Nicholas Jones Sabre May, 2001 1m37.3358s
Formula Libre Brian Sampson Dallara February, 2000 1m23.6319s
Formula Two Paul Stephenson Dallara June, 1999 1m23.8310s
Formula Three Michael Caruso Dallara 301 Fiat September, 2003 1m17.4600s
TOURING CARS
V8 Supercars Jason Bright Commodore VX August, 2002 1m23.1514s
Super Touring Jim Richards Volvo August, 1998 1m25.3181s
Future Touring Ray Sidebottom Commodore VX October, 2001 1m31.4544s
SUPERTRUCKS Inky Tulloch Freightliner October, 2001 1m45.0925s
CO-Drivers Trucks Steve Coulter Isuzu SBR May, 2005 1m53.7336s
NATION’S CUP Paul Stokell Lamborghini Diablo G September, 2003 1m24.8430s
GT PERFORMANCE Bob Pearson Mazda RX7 Series 8 September, 2003 1m32.6533s
GT PRODUCTION John Bowe Ferrari Challenge August, 1998 1m29.1420s
V8 BRUTES Damien White Holden VY SS June, 2004 1m41.0480s
PORSCHE CUP Wayne Hennig Porsche August, 2002 1m28.3335s
COMMODORE W. Wakefiedl Commodore June, 1999 1m35.1286s
SUPER BIKES Shawn Giles Suzuki GSXR 750 May, 2000 1m23.733s
SPORTS SEDANS:
Over 2 Litre Tony Ricciardello Alfa GTV August, 2003 1m22.2930s
Under 2 Litre Ken Hastings Snr Toyota MR2 March, 2003 1m31.4735s
GROUP C Phill Kirkham Falcon XE October, 2005 1m31.3669s
HQ HOLDENS Neville Haley HQ Holden May 1998 1m43.8275s
SALOON CARS Tony Evangelou Ford Falcon EB May, 2001 1m38.6151s
V8 STOCK CARS Andrew Miedecke Chev Monte Carlo October, 2001 1m31.2853s
MARQUE SPORTS David Stevens Porsche May, 2005 1m26.6358s
APPENDIX J Ian G. Jones Torana XU1 July,1998 1m37.8448s
IMPROVED PRODUCTION Phil Morris Datsun July, 1998 1m34.3156s
AUSTIN HEALEY Rob Rowland Austin Healey November, 2001 1m43.8940s
DAEWOOS Ian Kegg Daewoo Lanos October, 2001 1m50.9913s
MITSUBISHI MIRAGE Matthew Coleman Mitsubishi Mirage July, 2000 1m37.8655s
Bridgestone from the Potenza family I belive. i see a fair few Porsches come in to my work with RE55S fitted for road and track.
well then...i like them...kinda partial to the Potenza family
so they are above the RE050
sweet
RellikZephyr
They are called Potenza S-03's and I can only get them for ~400 dollars a tyre in 235/40/18 and thats god damn Bridgestone wholesale prices!.
They stick to the road like all buggery in rain or dry tho, the best tyre wall and tread design I have ever seen.
Um, I think people are getting their wires crossed. The R compound Bridgestone tyre is the RE55. There are two compounds available in Australia - a hard & a soft. If you go to an ordinary Bridgestone shop you will probably get a blank look from the bloke behind the desk, so try the more motorsports orientated outfits.
  • 1 year later...
Another option for a good comprimise tyre is the Federal 595RS. Speak to President James as Federal are looking at giving SAUVIC members discounts on their tyres. He has some on his EVO now and they look pretty good.
http://www.federaltire.com/en/html/pdetail...line=1&ID=3
Anyone tried these Fedral's and did SAU ever snare a discount from them?
Any idea how they compare to the Hankook R-S2 for track work? Just they are a cheaper alternative to the RE55's.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
