Ok cool, damn turbos are a confusing business! So i take it this is the real GT3076R:
http://www.turbobygarrett.com/turbobygarre...R_700382_12.htm
So if I was to go to turbotech (local garret distributor) and ask for part number 700382-12 with part number 740902-2 fitted to it then I would get a GT30R .60 front/0.82 rear....right?
