OK as most of u are aware my stagea, and nearly myself too - met an untimely death at the hands of a pole.
The car is A1 from the front doors, back. Nothin rear of the front guards was touched, save for the side skirts are cracked but repairable, as well as the rear bar. Doors, trims, interior seats etc.
Anyone thats seen the car knows it gets cleaned, vacuumed and amouralled weekly, so if something pops into ur head u might want, let me know. Am happy to take pics if u want closeups of anything.
Cheers!!!
Rob
EDIT -
i have brand new shocks and coils from SK's group buy. Bilstein and whiteline, with the addition circlip grooves for adj height settings. Never quite made it to the car.
Edited by qikstagea
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/
  • Replies 98
I need the clips in the boot area.. I'll take a pic of whats broken on mine so you know what I mean lol
i had to get new ones of these too, cost me a whole $8 for one from nissan, probably easier to get them that way.
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2781945
sorry to hear wat had happened to your car though. Wats you color of your interior trim? Im lookinhg for a driver side rear door interior trim and how much? Thanks pal
BTW do you have whiteline swaybars? Will it fit 260rs? and how much?
Edited by stasis
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782006
- AIR DEFLECTORS!!! (I've got dibs!)
- Your rear diff (complete diff inc housing, going to weld it/drop front shaft for some RWD fun)
- Handbrake pads (If in decent condition, I need new handbrake pads)
- Plastic surround on front driver door skin for the handle to open the door.
- (NOT SURE IF YOU HAVE IT) The motor in the rear hatch that closes the boot itself.
Will think of more later :)
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782771
oh yeah i forgot the difference between S1 and S2 shocks my bad!! scratch me out on the shocks etc. then thanks.
i know its a S1 but are the tail lights S2? if so i want em as i have a cracked lens in the drivers side unit on mine.
also did you have upgraded coil packs (splitfire) or similar?? on your engine, if so i'd like dibs on them please, if they are rescuable of course that is?
Edited by oxford1327
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782923
wol., Why won't rear shocks fit? I believe S1 and S2 shocks are the same.
oxford has the manual version and they are different. there is a fair bit of evidence that the manual versions have R33 GTR running gear hence some parts that were expected to fit do not.
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2783033
So manual S1 and S2 plus 260RS has GTR rears. Ok cool!!
There was no manual s1 (apart from the 260RS) - so just the manual S2 (ie the rs4s) and the series 1 based (upgraded a lot!) 260rs (If they had done a series 2 260rs - ie a S2 upgraded to r34 parts - I would have bought one! :) )
Ian
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784394
i think that there is a series2 autech/260 rs for sale in QLD at motorman imports. but whether or not these "genuinely" exist or are a conversion i am not sure, maybe one of the guru's will be able to shed some more light on this?????
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784426
i think that there is a series2 autech/260 rs for sale in QLD at motorman imports. but whether or not these "genuinely" exist or are a conversion i am not sure, maybe one of the guru's will be able to shed some more light on this?????.
in the meantime i will try and find a link to the ad for it and post it up here.
stay tuned.
cheers oxford
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784429
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
