I decided to return my air intake to standard, as such I have a complete cold air intake kit for sale, ready to bolt on to a turbo or non turbo R33. Perfect fit.
- The apexi pod has been on the car approximately 16,000km. I have cleaned it every 2,000km so it is in as new condition. It comes in the original box with the 2 mounting brackets and all screws required to mount in an R33.
- The fibreglass cold air box was made professionally and I purchased it from UAS. It has all the cutouts for a turbo R33. The finish is very good and it is very effective at shielding heat.
- I will also include the cold air ducting I was using. Fitting this made a noticeable difference!
Price: $260
Will separate, make an offer.
Will ship interstate at purchaser's cost. I'm in Melbourne.
https://www.sau.com.au/forums/topic/149114-apexi-pod-cold-air-box-ducting/
I have a UAS alloy box for my pod.Where is your ducting located and where does it run to?
i just left the standard intercooler pipe in,which takes air from where the standard cooler was and feeds it under my pod.Do you have any pics of the setup?
Price: $260
willing to swap for something?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
