  • Replies 161
Originally posted by INASNT
U r right about the habibs tho cereal, all those vl turbo drivin wankers have upgraded to r33's!! its suxs
I had a VL Turbo.. and now an R33.. and im not a habib wanker..
Your so very quick to throw generalizations INASNT :P
teh GTiR is an awesome little machine.. and I beleive will munch many a GTST.. hell, i rekon they'll give a fair whack of GTRS some whoopass as well.
Definatley a little car id love to own...
Bren, you're right, you're not a habib. But you are from Melton so it's kinda like the same, ain't it ;)
How's the skyline going? Done any more to it since I last saw it at the Lorne cruise?
heh.. :P I knew that.. i just like stirring the pot..
:shake:
there are so many r33's now near where i live i see about 5 a day, and most of the drivers look like they used to or should be drivin vl's with inteceptors dumped on its arse with a turbo badge they pinched off sum1's car at the local shopping centre, if u get my dfift ;);)
Originally posted by wrxkilla
Hey rev210,
I'll race you anytime. Give us a break mate.
No need to call our car a peice of poo.
Whats wrong, cant you afford to buy the real deal Mr Skyline Taxi??? Geez, your one of them, I drive a GTST, my car is better than everything on the road. MATE - ITS NOT A GTR
Go home.
Stock GTiR running Pod Exhaust 14psi.
I'll blow you out of the water. And I'll leave it at that.
Chill mate.
'Peice of poo' are your words not mine. Sure I have some opinions about the car that might sound a little depreciating but, I didn't knock the performance at any time. I might be a little envious that I can't fit into one because I like the idea of having a car that looks 'family' (ie: not mean or sexy) and can kick ass. Horses for courses mate. You don't like line's cause they look like taxi's I don't like GTiR's cause I can't fit in them (just cause they look like a *#%* box doesn't put me off).
Do you think your car is better than anything else on the road? sure you do! you would have sold it otherwise. Better than 'almost' everything then? I'm sure you believe that too, once again you would have sold it otherwise. What about better than everything else on the road? I can't say I do, there are a number of cars I would much rather be driving than the R33, I just can't afford them or they don't fit my application well enough.
BTW, can afford to buy a GTR, just didn't because the gtst is the car I use for work (better fuel ecconomy).
I have only done a 13.4, what have you got to worry about? thats pretty darn slow. From the sounds of things GTiR's will kick my ass on a good day, then again talk is cheap and racing is fun.:P
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
