  • Replies 161
Originally posted by INASNT
U r right about the habibs tho cereal, all those vl turbo drivin wankers have upgraded to r33's!! its suxs
I had a VL Turbo.. and now an R33.. and im not a habib wanker..
Your so very quick to throw generalizations INASNT :P
teh GTiR is an awesome little machine.. and I beleive will munch many a GTST.. hell, i rekon they'll give a fair whack of GTRS some whoopass as well.
Definatley a little car id love to own...
Bren, you're right, you're not a habib. But you are from Melton so it's kinda like the same, ain't it ;)
How's the skyline going? Done any more to it since I last saw it at the Lorne cruise?
heh.. :P I knew that.. i just like stirring the pot..
:shake:
there are so many r33's now near where i live i see about 5 a day, and most of the drivers look like they used to or should be drivin vl's with inteceptors dumped on its arse with a turbo badge they pinched off sum1's car at the local shopping centre, if u get my dfift ;);)
Originally posted by wrxkilla
Hey rev210,
I'll race you anytime. Give us a break mate.
No need to call our car a peice of poo.
Whats wrong, cant you afford to buy the real deal Mr Skyline Taxi??? Geez, your one of them, I drive a GTST, my car is better than everything on the road. MATE - ITS NOT A GTR
Go home.
Stock GTiR running Pod Exhaust 14psi.
I'll blow you out of the water. And I'll leave it at that.
Chill mate.
'Peice of poo' are your words not mine. Sure I have some opinions about the car that might sound a little depreciating but, I didn't knock the performance at any time. I might be a little envious that I can't fit into one because I like the idea of having a car that looks 'family' (ie: not mean or sexy) and can kick ass. Horses for courses mate. You don't like line's cause they look like taxi's I don't like GTiR's cause I can't fit in them (just cause they look like a *#%* box doesn't put me off).
Do you think your car is better than anything else on the road? sure you do! you would have sold it otherwise. Better than 'almost' everything then? I'm sure you believe that too, once again you would have sold it otherwise. What about better than everything else on the road? I can't say I do, there are a number of cars I would much rather be driving than the R33, I just can't afford them or they don't fit my application well enough.
BTW, can afford to buy a GTR, just didn't because the gtst is the car I use for work (better fuel ecconomy).
I have only done a 13.4, what have you got to worry about? thats pretty darn slow. From the sounds of things GTiR's will kick my ass on a good day, then again talk is cheap and racing is fun.:P
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
