  • Replies 54
DIRECTIONS
I won't be at dinner, so y'all have to find your own way there. This is the location and map of Lucky's.
http://directory.ourbrisbane.com/directory...ngs/211758.html
As you are travelling along Brunswick Street (heading the opposite direction to New Farm (ie. as if you are going from New Farm park towards the train station), turn left into Martin Street (you will see the Coffee Club / IGA / Eagle Boys in the same complex (Central Brunswick)). Once on Martin Street, you can pretty much see Lucky's straight away on your left. There is a parking lot right next to Lucky's, which has 270 car parks, and is for use by anyone utilising any of the facilities in Central Brunswick.
Anna
i'm gonna have to bail sorry. money is not permitting this week. i either go tonight or friday's cruise. i picked fridays. sorry guys, will let you know if things change.
After reading all the posts, this is what I worked out:
Troy
Jason is a maybe
Lee is a maybe (he wanted to start at 8pm)
Jarrad is a maybe (starts new job today so not entirely sure if he can come)
Dave (zippo0_) is in if other people are going
Dave (Rhino) is not able to make it
Sorry but Marc & I cannot make it either
PS. normally the dinners are not like this, but it is just after christmas and quite a few people have come down sick...so hopefully there''ll be more people next week :nyaanyaa:
aww :P tis a very quiet one this week, could be because of everyones alledged new years resolutions of saving money?
i know that will hold me back a little but ill still come if ive ot the chance
:D just not tonight......otherwise id love to keep the loners company :nyaanyaa:
does this leave like 4 maybes???
Just a suggestion, can we have next weeks on northside? I know of a The land of goat sphincter rings resturant near tombul (dont remember actual suburb) there is normally live belly dancers.
just a suggestion
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
