hey everyone, just purchased a skyline gtst m spec s2 sunroof, man, white and stock as a rock standard exhaust and everything. goes very well quite impressed and im going to look after it like a gem. been reading alot of forums on this site and see that the rb25 gets some good power easily. a few mods i dont really understand like safc and things like that. so i was wondering what mods a turbo back exhaust, fmic, cai, pod and 9 psi would make on a healthy engine and what is a top notch perfomance shop that specialise in r25's. Also if there is a good site where it tells u what all different mods mean and how they affect the car.
Thnaks for your time
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/
Turbo back exhaust, FMIC, pod, more boost should see you around 180kw range.. With a fair few flat spots, and your car running rich.
So in this case, you have a few options..
One is to tune your car properly with an aftermarket engine management, such as Apexi Power FC...
With that all tuned up, you should hit above 200kw.. Dont forget to purchase a new fuel pump also..
Depending on where you live, check your state thread for details on workshops etc etc..
Heres a few sites that might help you!!
http://nissanskyline.6te.net/
Ok i only found one. .There was a site which had details about what each mod does and how you should go about doin it. Cant find the link anymore.. hmmm
Anyways use the search button here and you will find thousands of threads!!
Gdluck..
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794345
thanks mate for time to read and reply, what sort of price range am i looking at, 5 thousand including the apexi power fc and labour? and the most thing i want is reliability, i live in ne victoria and rajab racing are a reputable tuner about two hours away
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794383
5 grand??
Power Fc-Brand new - 1.2k-1.5k..
They have stopped making the power fcs, so its gonna be so hard to find one!!
OR, if you have the dosh asap.. Email [email protected] for a power fc!!
N i mean ASAP!!
Tuning ahould be about 600-650 max..
Edited by siddr20
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794400
Have a read of the sticky thread: Forced Induction Guide
It has links to a dozen thread that a person new to the scene should read.
Goes over basic mods, what works, what power to expect, what problems occur, and how to fix them.
Without a doubt all the best info you will find is right here in this section :P
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794409
siddr20: nah mate sorry i meant 5k including front mount and exhaust etc sorry i should of explained better..
r31nismoid: ok thanks i will have a go at finding these threads now and have a good read. good to be part of this scene
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794422
bamr33: yeah thanks for the info im new to the import scene and i can admit still trying to learn a fair bit of stuff as ive come from beig a holden guy but yeah checking out the trader forums now ta
Edited by r33gts-t s2
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2794726
Alan Rajab doesn't touch Apexi Power FC's
Take it to C&D Motorworks in Braybrook, another 20mins further.
Price breakdown:
Apexi Power FC - $1000 (and good luck finding one)
Apexi SAFC -II - $400 (Im selling mine if interested for $250)
Tuning - $250-350
Turbo-back Exhaust - $6-700 2nd hand at a wrecker
Bosch 040 Pump - $205 delivered (ebay - Mick Cita)
Hybrid FMIC kit - $640 delivered (ebay - Flying Performance)
Boost Controller Electronic - $2-300 2nd hand
" " Manual - $25
Good luck mate:
I use to have all the above with a SAFC - 11
and made 211.8rwkw @ 13psi
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2796858
thanks nabil thats really awesome power for realistically around 5k fitted.. i thought rajab was prettty good but c &d sound like the place to go. how do u go for reliability issues. i am interested for your apexi SAFC but bit tight for funds due to buying the car i want around a daily 200rwkw. would that keep up with a gen3 clubby you reckon
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2796923
powerfc is not being made anymore right?
my car currently has a turbo back exhaust and pod and is at 7/9psi - making 164rwkws.....
Perhaps keep the stock air box (i just got the pod cos i luv that sound :dry: ) and maybe the power might be just a teeny bit higher?
This is my plans for the car (already got exhaust & pod) - will be investing in a decent front or side mount intercooler, get one of slides high flow turbos, fuel pump, clutch, was going to get the powerfc (but i dunno what to get now that thats no longer in production), boost controller and upgrade the AFM. Not sure what I will be looking at in terms of power, but that will be found out on the dyno. From what I have read, this is what most people do anyway.....
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2796942
Gen 3 Clubby - :dry::O V8 LS1 :O
Their overated...but there are some beasts out there pumping
over 300rwkw...lets seem them put that power to the ground!!!
With 198.9rwkw on 10psi I ran 13.7 @ 105.5mph with 2.36 60ft (lots of wheel spin)
The mph I got is really a 13.0 -13.2 1/4mile pass.
My last run at calder I lined up a Monaro CV8Z with exhaust ectractors and cold air
it ran 15.1 at 97mph...I left it standing.
200rwkw is very responsive and reliable on the street!!!
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2796943
some bits to help go quicker;
* 0.8mm gapped plugs (BCPR6ES) a few bucks each
* 10psi or so of boost boost control EBC for under $400 or bleeder
* Pineapples AKA rear cradle bushes about $100 --- helps you get traction
* Turbo back exhaust
* exhaust cam gear
* S-afc II
* upgraded clutch (the stock one dies very quickly) While your at it get a light weight flywheel.
* keep the stock airbox and run a high flow element
That lot is enough to run low 13 or high 12, with a healthy car and tune. Low 13's even if your traction sucks.
My old R33 had the above mods on 10psi odd made about 170rwkw or so and ran 13.3 with a 2.3 60ft (ie: wheel spin a-go-go), a few others have run 12's . This is with a stock intercooler by the way.
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2797000
nabil: not trying to start an argument or anything but my parents have a vy clubby series 2 with a di fillipo full exhaust and it goes very well for stock its ran a 13.7 and got the power to the ground, but i want to show my dad up with the skyline because he thinks they are rice but yeah i do agree with you 200rwkw should keep up with it shouldnt it.. cant wait to get these mods on..
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2797001
R33 RB25det as aposed to a Gen 3 V8 LS1 5.7 litre
has less than half the displacement
makes heaps less torque
and 2 less cylinders
Give us credit :)
Edited by Nabil
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2797091
nabil: yeah im on your side just saying they are powerful stock and i want to giv dad's a good run but thats not my main priority i just want a streetable skyline that has the power there when u want it.
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2797196
Do it right and you will kick your dads ass. :)
A mid to low 13 can be acheived even without the S-AFC, again if you do things sensibly.
The R33 gtst is basically a 13 second car with an exhaust and 10psi of boost, if your car is slower than that you screwed somthing up. Just don't go silly with lots of mods all at once, you may find you don't need all of them to get the car where you want it.
By the way 200rwkw of peak power isn't a very good goal. Think about average power AKA torque instead, thats what makes the car fast and fun to drive.
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2798828
mate if ur goal is to beat a V8...then u dont need to do much. Look for average power which gives u a good street response, none of this peak power stuff. Get better suspension setup, wheels/tyres or even just tyres Then work on driving it! Mine would do some seriously quick times if I could drive it... LOL
https://www.sau.com.au/forums/topic/149959-my-r33-gtst-s2/#findComment-2798933
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
