I bought this damage car because of the Advan RG mags they looks great and design to sell all the other bit and pieces!! Cars ony done 42000km
Price:
Whole car as it is $7000
Engine with loom and ECU $2500
5-Speeds Gearbox with tail shaft, Diff and two driving shaft $1800
HKS Suspension $1050
Front Seats $350 with rear seats $450
Door trims $220
Window switch both side $175
Rear wing with boot lip $140
Both tail light $120
3 inch cat back exhaust JASMA $425
All other parts available just PM me what you after thankyou!!
Car locate in Heritage Park Brisbane
Any question call 0430 073840 any time between 10am till 3am don't call between 3.01am to 9.59am thanks a lots!!
Edited by R34 GT
  • Replies 61
Posted Images
For the second time...
What condition are the sunvisors in (eg. moisture stains) and how much?
How much for the plastic surround on steering wheel (the bit between the actual wheel and dash fascia)?
I need a S2 fuel rail if its not damaged , no injectors required . Rail to manifold bolts and spacers would be good and the injector fixing screws and turrets please .
Thanks A , in Sydney .
Edited by discopotato03
where does the moisture stains?
plastic surround on steering wheel $65
how much and condition for the gearstick boot + trim,also postage to 2081 and rear suspension
gearstick boot + trim very good condition $85 inc postage
won't sell rear suspension only selling full set
can you show me what you need do you have picture??
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
