This question is not getting answered in another thread and I'm not able to find definitive answers.
I just recently bought a 33GTR and noted that on full boost it's sitting on 7 on the stock gauge, which as far as I know is around 13.4-13.6psi. I thought stock GTR's were supposed to run 9psi? Which would be about 3/4's on the gauge?
Here's a pic showing the boost solenoid, note that the stock restrictor is still in place inside that hose with the yellow mark on it. The only other thing I could find of note was the earthing cable shown which leads up into the back of the spark plug cover so presumably doing something for the coils. I note that the silver box beneath the boost solenoid has JECS written on it, is this stock? It's connected to the solenoid and into the fuse box.
Ideas would be greatly appreciated as I'm not comfortable with that level of boost on Ceramic turbo's especially in this hot weather.
Cheers
https://www.sau.com.au/forums/topic/150126-gtr-boost/
OK the plot thickens, I just thought to myself, I'll reset the ECU and see if that helps, in doing so thought I'd check it to make sure it was stock... guess what... It Reads Impul HI_POWER CONTROL UNIT then SGTR-1133
Wonder if that is controlling my boost?
https://www.sau.com.au/forums/topic/150126-gtr-boost/#findComment-2796994
It sounds all stock to me, as it is from the factory and will be fine. I beleive 7 is stock. However, bumped to get answers from the Guru's who know for cert.
Edit:
0.7 of 1 Bar with restrictor in.
1 bar with restrictor removed (appx 15psi).
Edited by Sinista32
https://www.sau.com.au/forums/topic/150126-gtr-boost/#findComment-2797633
The restrictor is definitely in the line, I've checked it myself.
700mmHg = ~13.5psi that's up around what people claim is the max safe limit for the car, with this in mind and the fact it has that Impul thing in it, I doubt it's stock. Can anyone tell me anything about the computer? Also, could it be controlling the boost? Surely there'd be a module or something somewhere?
I think I'll put the car on a dyno and get some more info on what it's doing too but next weekend, this weekend/week is all about servicing and fluids etc.
https://www.sau.com.au/forums/topic/150126-gtr-boost/#findComment-2797875
I'd suggest an IMPUL ecu is not stock, and yes a remap can control boost levels but so can a lot of other things. If it is at the boost pressure you say then rule of thumb suggests that it shoud be OK but your concern re ceramic wheels is valid.
My stock 32 GTR maxes at about 9 psi, 33 is probably similar.
JECS and DENSO make just about every electronic part on the car.
Dyno is a good idea, see what it's actually doing.
Edited by Scooby
https://www.sau.com.au/forums/topic/150126-gtr-boost/#findComment-2797913
I've gotta find out where the closest 4wd dyno is and go from there. It's definitely reading 7 on the stock gauge, I wanted a pillar mounted gauge anyway so I'll get onto that as well. I'm waiting on some info back regarding my options with the Impul stuff.
It might be valid to note that the car has an after market core, not sure what it is until I get under and have a look but hopefully it's keeping the turbo's cooler.
https://www.sau.com.au/forums/topic/150126-gtr-boost/#findComment-2797918
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
