Dan's on holiday at the moment and working from home.
Best way to contact him is his e-mail address, so e-mail him and he'll give you a contact number. Awesome guy and he's doing my major service this weekend.
He's been building a RB30/25 for somebody as of late and it sounds like he gives it 100% too.
He'll of course try his best to find out what caused it too so you know what else may be at fault.
Good luck and sad to hear about the engine!
i used john hill of JHH Engineering, prolly the best performance engine builder in aust thumbsup.gif
thats the funniest thing i have read in a long time, id be more worried about finding more sand in my engine than in the sahara desert.
Hey Ben,
I know of another mechanic who used to send his work to JHH and suffered the same sandy fate.
from what i heard all u got done to the head was sandblasted and john gave it back to you, so if u didnt check it, its ur own fault :worship:
the head was sandblasted and ported by somewhere else and given the workshop in question for a full head service, that includes cleaning out the head.
But you really are the expert on heads arent you shane????
from what i heard all u got done to the head was sandblasted and john gave it back to you, so if u didnt check it, its ur own fault :huh:
You should really try not to make comments like this when you have no idea. Who gave you that information?
The head was sandblasted and ported and John was fully aware that the head had been on the sandblaster. The head was completely stripped when I gave it to him and I payed in the vacinity of $600 for a complete head service including valve regrind etc.
The block and head are at another engineers now after engine failure and it has been found that the gallery plugs have not been removed from the block or head. The gallery plugs were not removed from the crank AS REQUESTED for cleaning, and the cylinders were bored with insufficient clearance for the pistons even though the spec sheet was supplied with the pistons.
As a result he destroyed a set of ROSS piston rings
He nearly destroyed a full set of brand new ROSS pistons
He destroyed every main and conrod bearing.
He nearly destroyed a brand new N1 oil pump
As I am a man of my word I am covering the engine under warranty. This is costing me around $1000....maybe a little more.
So please do not make comments like these when you don't know what really happened.
Oh, and I'm not bagging out JHH engineering either....who knows, maybe he just forgot to check that stuff in his old age. Fact is I payed him for a job and he only did half. I know I will never use them again and I will never recommend them to anyone ever again. I think I payed for that right.
WELL I WOULD PUT IN A VOTE FOR JOHN AND WILL AT JHH.
BUILT MY RB25/30 DET AND IT GOES LIKE A SHOWER OF SHIT FOR A 35/40, STANDARD VL FUEL SYSTEM AND 25 INJECTORS. IM VERY HAPPY AND IN THE EVENT I GET ANOTHER PROJECT CAR(f**kED IF I WOULD PUT MYSELF THROUGH IT AGAIN) I WOULD DEFINATELY GO TO HIM AGAIN.
HORSES FOR COURSES BUT I WAS HAPPY.............
MY 2C
CHEERS
IMTORQING
MY 2C
CHEERS
IMTORQING
That's nice....but why are you shouting?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
