Okay so this is probably a pretty common topic but I'm at a loss for where to go next with my mods so I'll start with the current list:
S1 R33 GTST
TD06 turbo
3inch turbo back
FMIC
Profec EBC
SSQ BOV
Turbo timer
Tien/Bilstein springs/shocks
OS Giken twin plate
I was thinking my next step should obviously be ECU upgrade then I thought I could probably use a box for my pod filter and some cold air but then I got to thinking that fuel upgrades might be more important first. I'm not really bothered (don't care) about asthetics at this stage and this is my first serious performance car so I don't want to pour a huge ammount of money into something I'll probably sell in a year or two.
Between now and the next big step I have a few small things planned like a catch can and HICAS lock bar, possibly an oil cooler too.
So basically my question is what's the most important thing for me to get into next? The car is just a street car and I'm only chasing a reliable 300-350hp atw but I'm hoping to see some track time and I do go to the drags a bit.
https://www.sau.com.au/forums/topic/150720-what-next/
With that set up and ECU should get you in the mid 300's. Just be careful as stock internals don't take much more than that for too long, 350 as you say is good and safe. Also your gearbox would be the next weak link. They would be next major mods. Small mods would be as you say, cold air intake, catch can etc. With the upgrade of ECU you can then upgrade injectors etc too.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2805167
He clearly needs neons and a huge drift wing :nyaanyaa:
I'd be doing injectors, ECU and fuel pump all at the same time and getting a final tune.
You can't up the boost without more fuel, the standard ECU won't support larger injectors, and the fuel pump won't flow enough for the added power. Pretty big outlay but you'll finally get to crank the TD06 up to max.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2807589
hold your foot flat and see what goes first, pistons or rods, we can all place bets.. im sure there is alot of guys with alot less then 350 who's engines have gone bang, guess it depends how u drive and whos going to build it as to how long your rebuild will last, and also how heavy your wallet is....
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2808257
The rods seem to be the most common weak point much over 350. Drive quiet and it will be fine over that but what is the point in that?
ECU, some will recommend PFC, if you wanna ditch the AFM etc go for a Wolf 3D.
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2808898
S1 R33 GTST
TD06 turbo
3inch turbo back
FMIC
Profec EBC
SSQ BOV
Turbo timer
OS Giken twin plate
what type of td06 are you using? (td06-20g or td06-25g and what size rear housing 8,10 or 12cm?)
I would go with the following mods:
ECU (Apexi PFC - you should be able to find a second hand one very easy, as they no longer make them)
Fuel Pump (tomie,nismo etc etc, they are all bolton and will supply you with enough fuel)
Injectors (NISMO 550cc or 740cc; because you have an rb25 get nismo as they are direct bolton, unlike sard injectors)
AFM (z23 afm + z23 afm plug)
go get a tune and depending what type of td06 you have you should be in the 300rwhp range.
Reliable depends on your tune, im running 337rwhp @ 16psi with 11:1 AFR (rich tune) (100,000km) my car see alot of limiter smashing and bashing, abuses from antilag and i do like to do abit of track work (drag,mc and drift when i can get time) AND i havn't had a problem yet
(my engine is unopen stock rb25det)
good luck
oh and if you need some help finding a second hand pfc, i can source you one
-Michael
https://www.sau.com.au/forums/topic/150720-what-next/#findComment-2820316
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
