  • Replies 64
Posted Images
Niiice. 200+awkw with no hiflow turbo. Is that the bonus of manual and power fc?? Happy boosting!!
well cos its a rb26 engine in it not the rb25. I was being told that the rb26 are much easier to mod to get alot of hps
ohh ben told me that the car was only making about 150+kw@wheels before the tune and after tune its 236.5kw. So theres a gain at about 86kws@wheels.
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828681
nice work - knew you'd be happy.
just a note - probably in rwkW - ben's dyno is a 2wd dyno :yes:
yea true but remember that he didnt disengage the 4wd. and all 4 wheels were on the rollers so i assume its still 4wkw though dont you think? :(
Thanks cruisy. Im real happy with it.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828890
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :yes:
Good result, RB26's can get some tidy power out with relative ease!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2828939
excellent result. sounds like awk to me..... would have thought 236rwkw was a tad low for a tuned RB26dett, whereas 236awkw sounds about right. nice curve on the dyno graph as well, looks like a tune performed well by a professional. bad luck about the holdups but meh, Yudi Im sure you're happy at the end of the day :)
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2829292
Unless he has purcahsed a 4WD dyno in the past couple of months... there isnt 4 rollers on a 2WD dyno :sleep:
Just spoken to ben this afternoon and its a confirmed 236 :kiss: .5kw@4wheels
Edited by stasis
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831560
thanks guys for the compliments.
Pictures to come as soon the car is washed and i will take a few good shots for everybody to enjoy note everything looks stock standard tough.
To the questions :
1. Mods i did was just a K&N drop in replacement filter, can gears and power Fc thats all of it. Ohh like wat tangles said its running at 1 bar boost with stock std boost controller.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2831583
i dont know i didnt ask. If the man say it is then it is. Im just going by his wirds thas all.
Meanwhile we are at that i have been told to use 10w-60 Castrol. Can i use 15w-50 or 20w50? Its other brands not castrol i hacte Castraol. im thinking of using Mobil1 15w-50 or Amsoil 20w-50.
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832154
I saw the car on the dyno yesterday at Ben's, its definetly RWKWS..
Front wheels sit on a ramp, not rollers....
throw another couple psi boost in it and you'll get your 250rwkws, but risk blowing the turbos..
By the way, very tidy car!!!!
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832195
All the cars use Castrol Edge 10-60, the two motors he's done for me have, even before one was built
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832349
Thanks man. Well im just going by Ben's word and he said if its rwkw that will put it up to about 250kw. so...
Another thing guys fuel gauge. Just wondeirng when you switch everything on the ignition. Soes the fuel gauges goes down to E or it stays at the watever level is your fuel on?
https://www.sau.com.au/forums/topic/150811-racepace/page/3/#findComment-2832933
    • Looking to do a turbo conversion on my RB25DE Neo Does RB25DE Neo lower intake work with RB25DET Neo Upper intake manifold?    I found an upper only intake manifold for sale but not sure if it will fit the bottom  half stock intake manifold I have already? Thanks  Also if your selling any parts relating to RB25DET Neo pls reply below or dm.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
