which option
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
here's the thing, i'm looking to a new project in the very near future and i have a big choice that i can't make a decision on,
i want a coupe to drive as a daily, i have the HR30 sitting here with only minor things to finish to get it on the road but i drive an r31 GXE with an rb25det in it and love the rb25det, i'm a huge r31 fan and love the club meetings/ cruises....
Do i go the rb25det conversion to the HR30 or sell the GXE buy a HR31 and convert that?
https://www.sau.com.au/forums/topic/150815-future-plans-ideas/
keep the r30... much better platform to work with, More classic styles, and lighter chassie :)
I like both ideas,
it would be easier to do the HR31... but
how many R30 monsters are out there? it would be an absolute weapon.
compliance/engineers would take a bit though...
i would buy the gear out of your R30( what you got exactly?) and put it in mine, :) and you could use the cash for the RB25 conversion!
I like both ideas,
i would buy the gear out of your R30( what you got exactly?) and put it in mine, :/ and you could use the cash for the RB25 conversion!
go the HR30 RB25DET it will turn alot more heads than a HR31 HR30's are twise as rare as the HR31's and just for the record im not baging R31's i love them just as much as R30's
... but
Weapon ???????????
Can't use anymore than about 350HP but an RB will do it a bit easier than my L series.
One day I might throw down the gauntlet and find out lol
Cheers, D
brakes are easy to upgrade without dr30 struts. Just use Hilux 4pot calipers, wtih 280z hubs. And a rotor to match. Im in the middle of doing this myself :wub:
i already have s-13 coilovers with r32 4pots and matching redrilled rotors on the HR30... :wub:
if i needed to upgrade i'd find a set of HR31 struts and work with those...
if i did go the HR30 way i'd have the speck to an engineer first about the body to see if strengthing and mods for the rb25 box to fit would be required, thier my only concerns with the HR30...
the other plus is that i'd have a very healthy budget to work with if i used the HR30, on top of this i could sell the GXE and i don't have to buy a project car....
Edited by rsx84
  • 4 weeks later...
Ok, plains are as follows.....
rb25det with matching manual conversion, r33 or r34 depending on halfcut costs....
DR30 rear end rotor to rotor....
New LSD....
5stud conversion....
New rims......HUSH HUSH on these......
new coilovers...
brake upgrade....
custom FMIC set up....
full 3" stainless exhaust....
new fuel system.....
a bunch of bolt ons and plugs ins......
interior dress up/ re-trim...
should be a real head turner as well....
i'm hoping a 6 month turn around from what it is now to something special......
New LSD....
new coilovers...
brake upgrade....
Good idea. SAme way im going :D. Hope to have mine done by christmass, Unless the missis gets knocked up :)
DR30 rear end rotor to rotor.... >>> Z31 slotted available from RDA
New LSD....
New rims......HUSH HUSH on these......>>>>> Probably another set of Watanabes & doesn't want to attract the heat :):D:(
new coilovers...
brake upgrade.... >>>> not Commodore pleeeeeeeaaaaasssse?
full 3" stainless exhaust.... >>>> stainless is a waste in other than mufflers
Check out my PM
Cheers, D
  • 4 weeks later...
Plans for mine as follows.. registerable pending:
RB26 single turbo conversion (otherwise stock)
RB25 Box
3inch mandral
bigger cooler
management yet to be finalised
300zx rear end(r200 LSD and brakes)4spot ZX up front with stud and offset conversion to suit 17's
half cage
sways, and strut braces
*Done and dusted, and will more than likely smoke some of the newer models out there with the powr to weight ratio..
$25,000 budget
New LSD....
new coilovers...
brake upgrade....
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
