ECU
135 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Guys,
Its time to get the R32 Rb20 tuning sorted. At present Im running the Stocker with a Jun rechip, at present it seems to be having a remap issue. Its also misfiring a little in the higher rpm. The car has two extra injectors connecting to a Greddy Injector Controller Rebic. At present the car is running 320-330hp at the wheels.
Wondering what you use, recommend and why. Im doing a little research before I commit and want to know whats out there.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/
  • Replies 162
atm i have a mines ecu but i am getting a wolf 3d v5 because it has a lot more refinements than pfc only problem with wolf is finding a place to tune and i have found the experts :)
pfc is also good because its an idiot ecu because just about anybody can tune them
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2812116
depends on what you want, if you want a stockish car, and no wank, go a PFC, or a lumpy/bikirom, will behave like stock, drive like stock, and handle your extra power, otherwise go the autronic or motec route if you want to spend some decent fold, both will suit your requirements and more..
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2812366
Best value for money is the Wolf hands down. My silvertop 20 is kicking out 274.8rwhp with 3 inch turbo back, RB25 turbo, Blitz BOV, fmic and Wolf 3D (stock injectors etc, nothing else in the engine touched... yet). Also gets rid of the common AFM problems you have with 20's. PFC is good but a lot more basic, especially in comparison to the V5 Wolf but similar in pricing.
From what I can gather, the Wolf will also get you better fuel consumption that a PFC. More tunability etc. My car off boost is awesome on fuel, can get nearly 600 to a tank now days. On boost when fuel is needed it is there.
Edited by R31 Chick
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2812896
unless you need the extra features of a wolf/autronic/motec type ecu you cant really go past the powerfc
plug in , stock idle a/c everything controlled perfectly , the most popular ecu by far with the most tuners by far and cheap
only problem is getting the old discontinued ones now
but i guess if you got the $$$ to burn go full wolf/autronic style with antilag , launch controll , flat shifting the worx!
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2813079
lumpyrom ftw! handles my street car and my track thrasher smashing limiter all the time with 300rwhp and hasnt broke yet. If i wanted to step up it would be autronic, or for a powerful street car pfc. All the tuneability in the world with proven results and actually has people who can tune it and not blow ur car up with a dodgey 2nd rate ecu.
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2813165
my car came over with a microtech in it...
fuel efficiency was terrible, i could drive like a grandma, or sit on the limiter all day, and get the exact same km per tank.
swapped it for a PFC, and bar the little hiccup mine had, it's a great ECU, lots of tuners, and widely used. :P
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2813290
Really if properly tuned they are all good ecus. And thats the catch....an ecu is only as good as the tune.
As someone else has said find a workshop that you are going to use, ask what ecu they tune and recommend, have a look at some of their results and go from there....
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2813432
PFC D-Jetro, rid the AFM's (soon anyway...) just for something different. Easiest/cheapest piggyback ECU solution with great tuning options and the hand controller.
Microtech was too expensive as were other aftermarket ECU's like GRedy E-manage and HKS F-Con Pro, I was told to steer clear of Wolf3D. LumpyRom and Autronic I never considered at all.
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2813461
Considering that AP Engineering no longer exists, is it possible to get someone else (i.e. a performance shop) to modify an RB25 pfc to suit an RB20?
Edit: personally, I am going to go for a remap of my stock ECU until I can fund an RB25 transplant, then I will fork out for some aftermarket management :huh:
P.S. I saw something mentioned about Hyperdrive being sold.. does that mean no more new LumpyROM's?
Edited by bubba
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2814424
Always depends who you talk to as to what you hear. Think about your budget and what you want from the ECU, then make an informed decision. A lot of different ideas from different places and they aren't always based on fact.
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2814854
The fuel economy has nothing to do with the ecu, its all to do with the tuner.
I know wolf's get good fuel economy because the tunes you get in WA are so lean, they just melt the piston out of the motors. which makes fuel economy really good .
PowerFC all the way. The votes speak for themselves.
https://www.sau.com.au/forums/topic/151104-your-ecu-choice/#findComment-2814859
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
