  • Replies 81
Yup.
I have 2 buckets in 2 corners of my shower - when full, these water my tomato plants.
When doing the dishes, I collect the water while im waiting for the hot stuff in a jug and that waters the roses.
I dont leave the tap running while I brush my teeth.
If you dont have one, install a toilet with a dual flush system - and always use the 1/2 flush (unless you need to use the big flush).
Also have a connector thingy and a long hose, so that when the washing machine drains it goes out onto the garden, instead of down the drain.
Quick showers.
Wash with a full load - be it clothes, dishes, etc - dont waste water on just 1/2 a load.
I see little point to be honest.
When household water useage only accounts for a very small percentage of overall water use, and even smaller propotion is wasted water, its just a typical case of the Gov't looking as if they are "doing" something.
The real water wasting comes from Commerce & Industry ectors at a much higher waste and useage rate than the common household.
If you do some reasearch into the wasteage going on up in the irrigation areas up near the murray, BILLIONS of litres are lost each year because the Gov't does not deem it "cost effective" to pipe the open channels.
Now... IMO, cost should not matter at all, because once a dam is dry, its dry. Then the REAL cost will be felt
The Gov't quotes figures of around 700-1000ltrs a day for a household use.
With two people in this house, we wouldnt even come half way close to that. Fair enough a house with 2 Adults and 2 kids would... but two blokes, no chance.
nobody's gonna stop my 20 minute showers... you hear me... NOBODY!!
PS errr... why go nude just to piss in your backyard? surely just unzipping is enough
I cbf getting dressed for a morning wee... the grass is hating it though, those yellow patches are slowly taking over...
When household water useage only accounts for a very small percentage of overall water use, and even less of that propotion is wated water, its just a typical case of the Gov't looking as if they are "doing" something.
The real water wasting comes from Commerce & Industry sections at a much higher wasteage rate and useage rate than the common household.
Very true. Commerical water saving is where its at!
BTW wtf is John Howard thinking of using Nuclear Power?? Does he know how many thousands of litres of water a day the nuclear reactors need for cooling????????? In Europe and America yes, they have plenty of water, but not in Australia... at least not the south part.
right on!
never been in the shower for any less than 20mins. i once stayed in there for 45mins :O but it was a very cold night with very hot water on :P
Edited by R-SPEC
also when i worked on the council,if there was a major leak somewhere we would turn on fire hidgrents<spelling<and leave them over night or even more.was a massive waste of water...
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
