Hi all. I was recently looking at the GCG catalogue and came accross Bell Mouth Inlets for all different sized turbos. I was wondering if they are just for looks or are used for power gain???
Below are example pictures from the GCG site. (www.gcg.com.au)
All replys appreciated...
RoB
https://www.sau.com.au/forums/topic/151672-bell-mouth-inlets/
A bell mouth allows the air to transition smoothly into a runner. If it had square edges a turbulent layer sets up near the walls effectively reducing the size of the runner so the amount of air that can be drawn in reduces. I have conducted multiple experiments in labs to verify the existence of this phenomena.
And it is Waz. Not only does it introduce horrendous turbulence, the bastard can suck closed at higher boost levels.
Nissan did an amazing job of the stock setup for the era, but it falls far short in some areas when the hammer drops.
  • 1 year later...
OK so i understnad that the difference in power would be in proportion to the car, the amount of power the motor is producing and what mods are being used but what sort of power difference are we talking about???
They fitted one of these in one of the High performance Imports DVD's and tested the power gains, if I remember correctly there was a 1-2kw improvement.
I thought they were just a funnel so it can suck more rocks in LOL
Seriously the power increase depends on what you are comparing it to, if you compare it to a high flow with a stock intake there would be gains(as the standard intake sucks closed) However compared to a well setup intake, there is minimal gain.
I should know all about this, I have an exam on it next week :teehee:. What Geoff said is spot on. Bellmouth intakes are generally used because the duct loss is so slight it's considered to be zero, makes it easier to calculate things. I'd be interested to see the cfm output of a turbo compressor at a given rpm with/without a bellmouth intake. Maybe if you went from stock intake piping to bellmouth intake sticking out your bonnet you might notice a difference but otherwise I doubt it.
lets not forget a map sensor for all you Afm boys and girls out there. .....initial cost of the exercise for a 1 or 2 kilowatt gain....it's a little impractical
No, you use it inside a larger pipe or in an airbox. Take a look in the stock ones on a Skyline. Little bellmouths. Also in the HKS pod (which is a piece of junk BTW) there is a nice one with a gradual flare. Made a nice exit from the custom airbox on my race car which has the AFM, twin turbos and high compression 3 litres of goodness. But what would us engineers know hey Kyle. Drifters have invented everything so far, just ask them. Do well on the exams mate.
They don't need to be a full rolled lip either, just a nicely curved entry into the piping.
RoB
The bellmouth assists with the induction of small mammals and young children into the turbine without arms and legs getting caught up on the lip of the compressor housing :rofl:
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
