Sorry guys, i don't have a photo but i saw a white R34 coupe at Macca's Nunawading on Sunday morning that had a flush boot spoiler (no posts) that protruded about 100mm past the boot. Was wondering if anyone new what it could be and if they had any pics of it. Thanks heaps.
https://www.sau.com.au/forums/topic/151821-which-r34-spoiler-is-this/
Just wondering about the legality of that, it looks nice though,
Provided you still have a 3rd brake light (which i think is mounted in the boot lid on a 34 >_< ) that wing would be legal, as it looks to be completely made from fibre glass, even the supports.
nah al, any part that protrudes beyond factory bodywork is illegal...
eg where a "T" style wing protrudes either side of the bodywork it is illegal.
there used to be all the regulations on the vicroads website, but the buggers have taken them off or I can't find them anymore.
Don't forget the gaurds buldge out. My wing sits in a similar manner, but is still within the width of the guards, near the wheels.
Judging from that pic alone, i still say it may be legal.
PS: I know mine is illegal, as it is fully aluminium :)
From memory, the tomei drag car (the yellow 1 that was stolen) has a spoiler similar to that....thats just going from memory, so i'll try and find a pic to make sure I didn't dream it up
Edit: Nope, doesn't have 1... my mistake
Is this it?
It was like the sedan one but protruded back further, never seen one on these forums.
Hey,
Any ideas for other places to get that sort of lip picture cause thats the one I am looking for... Only seen it on a standard R34 2000 model GT.
Drew.
Is this it?
I was on the other side of the road as it drove past, think that could be it although it was all white and not sure if it had the separate wing at the back but then again maybe it did. Thanks heaps for your help.
Hey,
Drew.
Yep, Powerplay has this one but seems to defeat the purpose as the S2 R34 boot spoiler totally covered the factory boot brake light (cos it rusts) and this one has a hole in it to expose the factory brake light.
Wonder if it will fit series 1 then? Cause I already have the break light but it is lower down. I like the rear bar on that sedan wish I could get mine to look like that, thats the only thing i tend not to like on the sedan is the blinkers nad reversing lights i like the way the coupe has em setup way better.
There was one of those rear bars on E-bay for a few weeks, only wanted $170 for it and it was new.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
