Had a go at changing one of the round indicator lenses on the front of my 33 series II, I have got the whole indicator/foggie assembly out, and at the point where Im trying to unclip the lense. I can clearly see how these clip on but it seems as through they are so tight, that I cant get them off without doing damage.
Has anyone done this before? Is there some sort of silicone in between holding them on as well as the clips? Any ideas?
https://www.sau.com.au/forums/topic/151952-series-2-fog-lamp-and-blinker/
If they are anything like the headlight globes they should just kinda push in (the wire clip) and they kinda twist to the side but i am not completely sure as i have only changed the headlights. Just outta interest how did you get the indicator / fog surround out? i have a hybrid fmic so dont know if that is in the way for me.
are you trying change them to clear lense indicator?
If they anything like the headlights..
To get the headlight plastic cover off, it has to be baked in an oven to loosen the glue that holds it to the black backing having looked at mine a fair while ago I guessed that they would be the same, put up some pics if you succeed.
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
