I am having all sorts of problems getting good photos of white cars on racetracks (ie moving) when the sun is out. The panels on the care seem to flare. (If that is the correct expression). anyway, see the attachment for what I am trying to say.
Can anyone suggest any set ups tips (eg exposure length etc) for the camera. It is a Canon S2 IS.
https://www.sau.com.au/forums/topic/151957-taking-photos-of-white-cars/
The shutter speed (if that is what you mean) will go down to 1/3200 of a second.
The equivalent film speed is Auto*, ISO 50/100/200/400 equivalent (* Camera automatically sets optimum speeds.)
Specs are here if it helps...
http://www.canon.com.au/products/cameras/d...s2is_specs.html
I'm not so concerned about shutter speed as I am the ISO value. If you can manually change the ISO value, do so and set it to 100 for shots like the one in the example. Set the camera to shutter priority (probably on the main dial and indicated by the letters 'Tv'). Pick a shutter speed fast enough so that you're not getting blurred images but slow enough so that you're not losing too much depth of field. Pick a shutter speed (or range of speeds) that works for the conditions you're shooting in and make small adjustments up and down from there. If you see a white car coming and the current setting has been working fine for coloured cars, quickly bump the shutter speed to a quicker setting.
Hope this makes sense.
I usually set the camera to be able to manually select the shutter speed - mostly because it is in auto the car is gone by the time it gets its shit together. The speed I use varies, but typically is something like 1/400 or 1/640 or 1/800 (from memory).
The ISO speed has four (I think) settings - so I should use a lower setting for the shiney stuff?
BTW, what sort of DSLR whould you recommend for this sort of caper, ie cars on circuits.
Edited by djr81
If it's a super bright, really clear sunny summers day then i'd drop it to 50 (i think thats the lowest on your camera). 100 should be more than adequate though. Watch what happens to the aperture value as you increase and decrease the ISO setting for a given shutter speed. You'll get the idea.
One of the best enthusiast DSLR's at the moment is the Canon 400D. Very very hard to beat for the money.
you reckon the A100 lens kit is heaps better than the lens kit that comes with the 400D....
Since when do people buy a DSLR and not buy better lenses? The included lenses for the A100 are better than the basic, entry level kit for the 400D but not better than *any* L-Series Canon you could look at.
*STAB IN THE DARK* That same shot on a tripod and with a 4-5 second exposure at ISO 400 would have been less grainy and a better shot.
Have you played with the histogram yet? If not, learn what it does and go from there.
a white subject on a landscpe shot in broad daylight is going to be tough. there are better photographers than me on here but for my 2c, here are some tips:
- pay close attention to light metering and tell your camera where to grab the light reading from. if it's averaging across the viewfinder, the sunlight will wash out your white subject.
- try and position yourself so the sun is behind you instead of shooting into the sun.
- use a uv filter or a polarising filter to cater for harsh sunlight. a gradient filter may also allow you to control the wash from the top of the shot.
- use a lens hood
- i know some people use a dual exposure filter to assist (especially for landscapes with bright skies and dark terrain) but they freak me out and i don't fully understand them.
the 400d is god's camera. i would buy one in a heartbeat if i had the $$$.
edit: hmmm, on second thoughts, the 400d is not god's camera, but it is blummin' good. and definitely go the canon over the sony.
Edited by sigsputnik
Problem was the wind was really howling - to the extent that I couldn't get the camera to hold still properly. A 4 - 5 second exposure would have been better, but there was no way I could have got a proper shot with it. I had to use the 0.125 second & even then half the shots had the comet walking across the photo.
Played with the histogram. Not suprisingly everything was on the LHS for this shot.
That's a good tip about the lens hood. Get one and use it but remember to remove it for flash photography or you;ll get shadows over the pic.
I didn't look closely at the shot to work out it was the comet! Thought it was a plane flying over and I was spewing the other night that i'd missed seeing it. :huh:
If you want a challenge, get yourself onto the startline at WSID and try to take shots of white cars, at night, with their headlights beaming :(
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
