  • Replies 49
Posted Images
Love that Brown Davis cage! Must be so damn heavy lol. I had a Brown Davis rollbar in my MX-5 damn it was heavy.
I have the 6-point chromoly Cusco cage. What a difference it made to my car handling wise.
I also have the Do-Luck bar and noticed no difference in handling with it fitted. Tempted to take it out as it's just extra weight.
I also fitted HKS Kansai under body bracing, no difference in feel either. Out of all chassis mods on the cage was a clear difference in feel.
justin, does the b pillar brace interfere with the cusco cage at all? acutally your cage is what they call a 7 point as it has one cross bar at the rear. mine is the 8 point version with another horizontal bar at the back between the two strut towers. :P In the cusco dealers catalogue I have it lists all the weights for the cages. I think the 8 point ones are around 40kg all up :)
Looking at their website its 23.2kgs for a 8pt chromoly cage, that is for s13 though.
Justin, who did u import yours through? What were the shipping fees like?
I'm thinking if shipping is going to cost me a packet i might be able to get something made locally that is legal for the street as well.
I noticed that in yours Richard. Looks the goods!!! I love your seat... hardcore!!! PS: The Do-Luck bar does not interfere with the cage at all.
2630GTS: I get all my JDM goodies from Zi and Yonas at JDMyard.com. They're both friends of mine and I do the odd design job for them so I get trade prices.
260gts, chro mo cage is 23.2kg for 8 point for S13 or 30kg for regular steel 8 point for EVO. They don't list weight for the skyline cages though in the dealer catalogue.
they make them up to 15 point which is pretty hard core.
justin, good to hear the b pillar brace doesn't interfere with the cage, but it seems from what you were saying it's probably a waste of space and $$ so I'll just stick to the cage. with the rear horizontal bar I have anyway it should be pretty firm.
Fkn great thread!
Just one question guys, im from vic, r32, i was after a cage, im told cages are legal as long as they have padding everywhere and dont come within a certain distance between any occupants heads..
im after a cage where i dont have to remove the backs seats and re-register the car as a 2 seater but at the same time, i would like some rigidity...
i have seen the cusco half cages dont have that bar or 'triangleation' like the full cages, but will they be better then nothing? (ps to my knowledge, they are legal in vic)
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
