Left over from group buy.
Pics in thread in my sig.
Price..
Stagea Series I $120 with scoop
Stagea Series II $120 with scoop and engraving $30, Total $150.
Freight, Minimum $25, its very wel wrapped and packed in a custom box.
If you are miles out of town, then I'll confirm your postcode etc.
Who's in?
Also, new group buy underway.
Let mw know if you are interested.
BASS OUT
Excuse my blatent unadulterated noobness, but what are the advantages of this and why do I need one?
They shure look purrty tho....
They force the air coming through your grill to go through the radiator insted of hitting the radiator and going up over the top.
The scoop acts to foce air into the snorkel for your air intake.
They look Uber-cool.
I have 1 Series I, 3 Series II and 1 Series I with engraving.....
You know you want one.
loymclure
I only have one engraved Seres II
Series I is sold....
2 Series II (without engraving) are left.
  • 3 months later...
Hey ppls.
I will have 3 Series I Deflector + Scoop and one Series II Deflector and scoop spare in my current group buy.
Let me know if you are interested.
BASS OUT
  • 1 month later...
I have the following spares from the last group buy.....
$80 each plus postage ($25)
3 x R34 GTT Nismo / Series II BLACK
5 x R34 STD front bar BLACK
1 x R34 STD front bar bare, no powder coat ($70, it needs a polish, some minor scuffs)
4 x R33 GTS-T Series I BLACK
2 x R33 GTS-T Series II BLACK
1 x R33 GTS-T Series II bare, no powder coat
2 x R33 custom to suit R33 GTS-T with GTR Front Bar. Bare, no powder coat.
$120 each plus postage ($25)
3 x Stagea Series I with scoop
Come and get em.
  • 1 month later...
  • 4 weeks later...
  • 4 weeks later...
Hey ppls.
I'll freight them for free for the last 3 guides.
Stag Series I radiator deflectors with Scoop in Satin Black. $120 delivered.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
