Ok so there has been a bit of idle chit chat lately so i thought we would try a spotted thread for all you die hard posers :(
To get the ball rolling i spotted a very 2nd hand looking 32 that someone wants to swap for a A31 track car with all the goodies :laugh:
Knock yourself out people but dont abuse it, you want to post crap then take it to Whoretown :glare:
Cheers GMB
https://www.sau.com.au/forums/topic/152949-tassie-spotto/
SPOTO, Young GTR on the way to work in the NEW GTS2. Looks sweet, sounds good.
GMB , can we have discussions here about the cars spoted or just spoted.
Discussion to a degree but if you want to talk sh!t then take it to whoretown :devil:
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2845382
Spotted a LIME GREEN R33 with Veliside Kit front on hedding down past town outside Cathedral at about 3:30pm Monday 29th jan
:D you dont have to give us the full run down ya jack arse!!!
Im supprised you didn't post his rego, what he was wearing and if you thought his BF was good looking :(
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2862824
Well i figured that was a bit muhc, but his plate was FG3476, and he was alone. LOL. Nah i just made that up, JACK ASSSSSSSSSS.
Also spoted and white R33 an white R32 and a Black R32GTR all heading down the brooker last night.
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2863242
Probley Alan (al r33)
Nar it wasnt me i havent had the car out since the weekend! But there is another one people have told me about which is allready causeing me trouble with the cops! "Booked for Drifting on Kingston Beach Esplanade" when my car was not even on the road and at the mechanic getting suspension changed! I had to take it to court but i won in the end!
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2863970
Yeah i know the car your talking about, he is one guy that gives people things to bitch about import owners :wave:
https://www.sau.com.au/forums/topic/152949-tassie-spotto/#findComment-2864105
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
