Never seen it in the flesh, only in his signature (which doesn't show a huge amount). I'll take a look around on here for some higher quality pics and keep an extra sharp eye out for it out on the street. Sounds like a horrific crash with the blue 33, I had no idea... Horrible to see yet another one go to waste
Going to stop spamming and busy myself elsewhere for a while as this is hardly spotto-ing :rofl:
well empra was rolled into a brick wall and suffered quite a bit of damage, this was a few months ago though.
The front bar has a bit of damage where it looks like it's curled under the car and the bonnet looks a little bit long on the body (but I think that's just aggressive styling) as you can see in the picture. Either I'm seeing ghosts or she's back on the road with any major front end damage fixed and a patched paint job.
Pretty damned sure of the days I saw her, as I was scuttling back from work in the blistering sun attempting to look like less of a blob of sweat (being Tasmanian anything over 25 degree's is like an oven to me).
woulda been yup :) was on a cruise for a mate. what the hell was going on in cygnet??? like a bajillion people there
More than likely the redirected traffic from Margate due to the accident.
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :)
there's the cygnet folk festival (read: hippy festival). im staying with some friends - last night i went on down to huonville in the GTR and ended up in the middle of a cruise.. i was like what the hell! last thing i expected to see down here :(
haha i heard there was another GTR down here over that week. every one was telling me how nice it looked.
Spotto'd Funz in Kermit and a guy (I'm assuming Mr. Untouchable?) in his dark grey/silver R33 at the round about near the fork in the road today, and a nice white series 2 R33 a bit further down the road. Attempted to get an arm out the window for a wave but my drivers side is stuck closed :(
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
