was a good day :-D very slippery first laps out and that wonderful comp lock up into T1 haha.
was good giving you a chase, would of chased a bit more but my car started playing up, think the diffs giving up on me lol.
yeah, next time. I was silly to go back out, brakes were not exsistant on the ride back! bloody hell those QFM pads are good tho, worked awesome down to the indicator! just orderd a new set + spare set.
yeah, my brake pedal is feeling a bit spongy now haha was good though, these simple EBC green pads have done 3 track days and 2 hillclimbs now, holding up well :-)
im quite surprised how well the R888's went!
spotted my 33 not ideling & seeming to fuel up at around 4500 5000 rpm doesn't do it all the time tho im thinking afm? maybe igniter? as it has almost new spitfire coils any ideas? running around 13psi
edit if i unplug afm idles fine as soon as i plug it in wont idle
Edited by Autumn_180
Check the AFM insidey bits where the bits actually solder onto the board, I've read it's a common problem for them to corrode and crack, the just need to be resoldered.
If you'd like a spare one to test I think I've got a spare one lying around because my R33 doesn't need one anymore.
Also my house mate is pretty handy with a soldering iron if does turn out your afm is broken.
How'd you go with your brake master cylinder problem?
brough a new working one fitted it but the pedal is still soft theres no air in the lines or anything the fronts work fine but its like theres no pressure getting to the rear brakes
That would be good i can grab the space saver on friday so if its ok we can test that at the same time?
yeah sure, send me a PM and tell me what time you want to come round.
Woah, I sold the space saver to an Autumn_180, not you Autumn33, imposter!
lol
Edited by zoidbergmerc
just a heads up. if you unplug the AFM the ECU will run in limp mode so it will idle and do everything normally. ive seen similar issues before but it doesnt nessasarly mean its AFM.
ill swap your 33 for my 4 door now if you want to. ;)
i found it will idle fine, but you try rev it and it will hunt and carry on like a spastic :)
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
