Depending on the time I could have been me :/
It's sooooo nice to drive, I love it :D
Nah it was definitely Tim or I wouldn't have known the car at all :P In a way it's a pity that it's an auto, but in another way it probably suits the laid back style of the car..
Manual? I thought his excuse for not coming out last time was because it was an auto? I obviously got the wrong end of the stick, which happened to be on the other side of the forest..
yeah that and the hecktik gold purple paint r33, poor bugger went wizzing up the hill and the bonnet flew up, uhhh that bonnet will be munted, hope his roof n screen are okay.
one of my fears about the track after a weeks worth of rain, when you have a off, rather than dry dusty grass, you have wet boggy grass, your a lot more likley to bog, dig in and up and over you go.
the bonnet didnt look too bad later in the pits, when i passed it on track one hinge was attached, the other wasn't , bit of a dent in the top of window.
i had a nice moment coming down the hill to the back straight corner, rear kicked out, got it straight so went off road for a bit :P
I love my auto Stag, its the perfect daily for me. Also its "wife drivable" for when i've had a few too many :) I'd never buy another auto otherwise tho...
F-n aye!
i love turbo auto cars , WOT+boost through gears = :woot: , flat shifting is fun too :ph34r:
My stag has ign cut upshift... tis awsome. Just foot flat and press buttons. :thumbsup:
Big thanks to Toff for the lend of recovery truck and trailer to get a 'beached white whale' home.
Is the guy that owns that harlequin r33 on here?
Oooh , that's the same as r34 auto?? . no probs with the bus loan ;) i hear the trailer near took out your bonnet!?
Honestly I don't know... I'd say so. I'm about to put some redline auto trans fluid in the ol girl to get the shifts a little more solid.
Ha ha, yeah the ramp got a little close on the way down the hill. :thumbsup:
Justin.
Just spotted a black r33 with a green revolution racegear sticker on the back window doing about 100kmh up Montpelier outside of Zap gym and nearly cleaned up a car that was turning right when he overtook him heading towards sandy bay road. He wa being followed by the white r33 with the blue graphics up the side but he wasn't speeding. If anyone knows this dick tell him to pull his head in cause other than nearly tboning someone he is giving all of us an even worse rep and we don't need that. Luckily the cops were not far behind I just hope they got him. All cool if you want to do that shit just not the smartest place to do it in the middle of town!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
