spotted the usual young commodore/falcon drivers always trying to race the 33 at the lights, what's with people they seem to think they own v8supercars
lol true its funny as F@ck watching them take of like there at the drags and you just pugger :nyaanyaa:
Spotted brian's bus on the hill at basky today, unless there another bright blue 33 I don't know about.
There's a couple of others around of the same colour getting around Hobart, Taurismo33's old R33 looked very similar from a decent distance (400r kit etc on it when you get closer)
That being said, it was most likely Brian :P
Spotted zoidberg heading south around 5:30ish or thereabouts somewhere on the highway. Can't remember where, was a bit tired, but spotted it on the trailer.
I was going the other way in my own white r33 :P
same just after epping how did you go ?
Yeah I spotted yours up there swell autumn, mine was down closer to the gate next to a Silvia. So many 33s there lol
i thought that was yours, behind you was another black one then mine then a blue & gold one behind me, was a row of 33'sthumbsup.gif
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
