Nah I'm not working there anymore so that won't help! :P I'll usually Be either in my black S1 33 with the SAU tas sticker on my quarter window (straight pipe cat back so pretty hear able :P) or the mrs white prelude., either way I'll try hanging out the window/sunroof!
Who has the white 33 that waved to me o basky road when I was leaving???
Haha, like half way through the drifts? That would have been me if it was a series 1.5, I wave to everyone in a skyline (or anyone at all on that road) ;)
i spotted you also jay but no wave for me sad.gif lol
WHAT?! That simply cannot be! :P Were you on the road or in the crowd?
Btw were you down in Huonville on Monday? I was on a cruise with the wife and waved to a R33 the same colour as yours, but had a massive sticker on the back?
yeah man, I doubt you were trying though haha, her honda be slow :(
Her Honda be bitchin'. I saw Elise frying tyres at 95 degrees all the way down the street the other day. Honest to god.
(maybe not that honest)
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
