^^^ agreed.
I'm wanting to get out of the import scene... even though there are some awesome people in it, a majority now are douche bags or bogans..
In saying there are bogans, i am looking for possibly a VY or VZ SS ute haha.. or an integra type S.
Doesn't want to be a bogan.
Wants a commodore....
yeah useless post really.
nothing has changed at all, there are the people that appreciate their cars and mod them tastefully and the ones that drive them, bling them up etc. its just two tastes, usually a younger person who 'gets their first skyline' stereotyping i know, but no more than what has been done.
its how it is, its how it will always be.
what has changed is the number of quality imports seen on the roads (in the south anyway)
used to be some nice supra's, atleast 5 i can think of, 4 of them went to the mainland and one i'm not sure. used to see some really nice GTR's, i know some were stolen, some sold to interstate and some converted to motorsports only cars.
used to see some nice FD's, "Apexi" etc, now there is only 1 i see kicking about, belongs to a mate of mine.
just seems alot were sold interstate, crash/stolen etc and weren't replaced with more.
we had atleast two importers in the south, now both shut shop and gone. made a difference having a showroom of around 10 and the other keeping stock of around 6
anyways just a sign of the times, some nice 35's doing to rounds =)
on the flip side there is plenty of good datsuns doing to rounds in the motorsport (mainly circuit) scene.
Brad's monster 32, rod willit's 32, Jamie lonergan's 32, John brigg's 32, yogi burghart's 33, Leigh Wooly's 33 then Pete Nunn's old car not sure who bought that.
Nobes is building a Improved production 350z, plus the 370 that is being built =)
Burgz is building his car atm, should be pretty trick.
also not sure what is going on with PJ's 34gtr, no doubt that will be floating about before too much longer
no doubt there is a few i have missed
things only seem to be growing on the circuit scene anyway which is great =D
Can't really give an answer to the whole story but my stagea is taking a holiday in qld atm
Should be up and running in a neat-ish looking r31 soon tho
have to agree tho, i used to see a few more imports around but now i only see the bad examples driven by the arabs at uni (auto supra, loud as hell red z31, shitty silver r33)
i've seen this driving past my house a few times tho
looks really well done, sounds pretty good too
also just spotted that red 34 in the photo too
yeah i think i saw that one and a white 34 driving together on brisbane street
also the commo was at powercruise, is pretty tough, met him at the cup too...been seeing it more on the road lately
Edited by MatthewT85
  • 3 weeks later...
  • 1 month later...
Who is going to the R31 cruise on Saturday?
I need a lift from lonnie to Hobart to get my car so i can attend
So if your heading that way Sat morning let me know because that would be really helpful!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
