I'm having trouble at the moment trying to get the xenons I have on my GTR to sit inside the headlight fitting properly and not loose like it is now....it's kinda hard to describe in words but, I have included a photo of the xenons on my GTR and I hope that is enough for similar owners to understand what it is I am trying to get fitted properly.
If ANYONE can help me solve this friggin annoying problem, I will transfer $100 into your account for the help. No Questions Asked.
The problem really is pissing me off THAT badly.
Edited by JUN R33
Heh, those globes are not a H4 base. I think they are a D2S or something like that, which means they will not lock into place. They are NOT a direct replacement, modification will have to be made, I have never done a retro fit for globes - so I cant offer advice.
Cheers
Sumo
Did you not get my pm?
I have done numerous hid installs as well as retrofits. my dad is an electrical engineer and this is our field of specialty.
As I said, if you want, give me a call, and i can even get the stuff you need for ya if you're in sydney.
my numbers 0403 211 482
We know a lot about electronics as well as hid itself. PS: depending on what car you have, h4 is most likely not the one you need.
what gtr do you have?
r32s projectors are either h3c or h1. r32 reflector is h4. gtr33 is h1.
give me a call and I can tell you anything you need. if you're in sydney, you can even have a look at my setup, or i can have a look at your car and tell you what you need.
Cheers
Chris
Edited by MANWHORE
Manwhore: How do you go with the retro fit's? We were doing some testing with the XenonOz range of globes and found on an older car, that if the contacts in the switching were worn, that after the 3-4 flicks of the starter and the globe had not being lit - you would end up with no lights.
The HID stuff can initially take up to 30amps to start a light we found.... Thats big current draw for small switching.
Cheers
Sumo
Cheers
Sumo
If the switch is worn, then it's worn. There's nothing that can be done except either replace it, or do a makeshift repair to it. It's probably cheaper to just replace it with a second hand unit in good nick for $20-30.
Basically, even under normal use, the switch does get worn from constant switching. Increased current draw makes it worse. I.e. when people run 100 watt bulbs.
One of the cars that I was working on had a switch that was completely melted and shorting out once the battery was connected. I had a look out the front, and the whole headlight loom was melted and shorting out too. When I had a look in the headlight, the plug was melted and the reflector material was peeling. When I had a look at the bulb, I almost had a heartattack. I have never ever seen these for sale. It had a 150 watt bulb in there! 3 times stock wattage.
Anyways, with xenons, once they're started, they draw 35 watts. Which is less than halogen (55 watt). However, when they're starting, they draw more power.
Just so that my circuits can handle the power, I make a dedicated wiring loom relayed and fused from power. By doing this, you also make your switch last almost forever. Since the only current on the switch, is just the few milliamps used to power the relay.
That's what i did. It's the only safest way to modify the power supplied to lights.
Not slagging off sumo in anyway, but i'll be fair to Jun. He seemed like a reasonable person when I spoke to him on the phone. Sumo was not the first and also, the headlights that jun has does not take h4 bulbs.
I'll let you guys know what the problem was.
Jun's car is a sIII r33gtr. From factory, they have the d2s xenon bulbs in the projector headlight.
The previous owner of the car had swapped the sIII headlights with some standard sI halogen lights. These lights take a h1 bulb.
However, the previous owner had kept the ballast hooked up and just stuffed the d2s bulb into the h1 hole (of course it doesn't fit or lock in).
therefore, the solution is to remove the ballast and bulb, and wire up from the 12 volt source to a spade fitting to use a h1 bulb in the housing. The retaining wire was removed, so one needed to be fabircated using some metal wire. And a new dust cap needed to be sourced, as the previous owner threw it out.
This is the solution to utilise the sI headlights that are in there. An alternative is to buy sIII gtr xenon headlights for 2.5k
a h1 xenon kit can be purchased and put into the sI headlight that will fit, but I ABSOLUTELY do not recommend them in anyway. They'll have shit light output (less than the halogens on the road, and will be glary, because a lot of the light gets shot all over the place because the halogen housing isn't designed for a hid bulb. They have different focal points).
Edited by MANWHORE
  • 1 month later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
