Hi all I have a complete standard set of GTR rods, pistions and the matching GTR crank for sale.
$500 the lot.
Can send pictures of parts on request
Will send intersate at buyers expense.
Cheers Claro.
Edited by DRF72
https://www.sau.com.au/forums/topic/153017-gtr-crank-pistons-and-rods/
  • Replies 41
I'm located in ipswich the internals can be used in an RB20 if you are looking at building an RB24det. you have to use 82.5mm pistions with the gtr crank and rods.
wot do u want for the crank and rods
need to see some pic first though
sorry about the delay won't have pics untill monday night dig camera stuffed up. i'll sell the crank and rods for $500 and give you pistions fre.
I really don't want to split it up cos of 6 pistions laying around the shed not used.
cheers
claro
Sorry the parts are from a 1993 R32 GTR.
bro still intrested in the parts will they fit with just a bigger bore on my bottom
end without f**king around with forged internals and do u know how strong hosepower
wise they r
cheers
wise they r
cheers
The crank n rods are proven to support 400 - 500hp in a stock application, the pistons are the part that will let you down, its well worth your time to purchase the lot, and a set of forgies, if your looking for a lazy 400hp at the wheels and a bottom end that will hold up to the punishment for half the price of aftermarket gear.
Good Luck with the sale woulda grabbed them if they were out of a 33 :)
wots the difference between 33 and 32
  • 4 weeks later...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
