what are u wanting it to do.... just drive your car speakers, just drive a sub or a combination of both, do u want 1,2,3,4 or five channels??? I'm going for a alpine v12 700w digital amp - don't know the model no. it's two channels but that's all i need to run the 12" alpine sub that going with it - sorry i couldn't be more help
by the way... the amp retails for $399 from autobarn not to bad for a alpine amp, + u should be able to haggle a bit more of that as well, add a $200+ sub to it and u'll be kicking it up :-)
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-314342
what jaycay 5 channel amp??? neways check out the group purchase of the response 4x100wrms amps in this forum. They are the shit and we are getting them for just over 3 hundred bucks with a 1 year warranty but you must be quick. they normally retail for $449 if you buy 1. they can go:
4x100wrms, 2x100wrms + 1x300wrms, or 2x300wrms
they are wicked and i think best value for money. my mate ran 2 cervin vager 400wrms subs in a ported custom box of this one amp and when he pulled into my driveway the pictures on the walls moved... so think about it.
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-314424
Have to be bridgeable amp - not all of them are compatible to be bridged properly. Not sure the exactly electronics behind it but that is why many are labelled as "bridgeable" and some aren't.
My 2x75rms into 1x150rms sounds fine for my sub..
If u just want to run a sub.. and not lose 2x channels in your other amp... you're probably best just getting a powerful monoblock.. You can push a lot more through the one channel at a cheaper price than bridging.
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-315288
A "mono block" or just "mono amp" is pretty much what it says.. just runs the one channel.. which is dedicated for one purpose: running a sub (or two or three, etc) .
Looking at I guess $200 - $800 for one depending on the brand.
It can maybe end up a bit cheaper as you can probably get away with a smaller amp for your other speakers... as subs need comparitively greater power to achieve decent volume.
e.g. a 300 Watt (RMS) sub probably won't kill you at full volume.. 300 Watt "standard" speakers at full volume is ****ING loud :D
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-317884
so what you are saying is that its best to run to amps if intending to run a sub, yes/no. if yes is the case, may this be a problem if i only have 2 re outputs on my h/u or does it not have to reply on it. having said that, can i run a second amp say 2 channels to my 4 channel amp in which there are 2 channels free on the 4 channel then just use the additional amp to run the subs. confusing? impossible?
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-317897
  • 3 weeks later...
i just went to Jaycar and they are selling their monoblock 130w rms mono subamp for $140, reduced from $169, but the actual amp must be mount into a cavity on the sub-box,not a direct bolt on. This is good if you are custom building a sub box and want to intergrate an amp into the cabinet. The sub amp has crossover adj., as well as some other features, but i havent heard it yet, or read any reviews..... looks ok though
https://www.sau.com.au/forums/topic/15353-best-amp/#findComment-348332
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
