http://www.fullboost.com.au/records.php?class=19
Drag Radial RWD 6-cylinder
Cars must run treaded radial street tyres. Maximum tyre size limited to 275mm sidewall stamping. Mini tubbing is allowed. No chassis cars. Gasoline fuel types only.
1 VIC Kris Velkovski Holden Torana LC - CGMFLY Nissan RB30 CP 9.96 137
2 VIC Ryan Quinn Nissan Skyline R33 GTS-t - OBEHVE Nissan RB25 CP 10.12 136.30
3 NSW Shane Crichton Toyota Cressida MX83 Toyota 1JZ-GTE WS 10.17 137.41
4 QLD Keith Lawrence Holden VL Calais - MAXPSI Nissan RB26 WB 10.35 135.87
5 QLD Mathew LeGrand Toyota Supra JZA80 Toyota 2JZ-GTE WB 10.419 138.08
6 NSW Nabil Morcos Toyota Supra JZA80 Toyota 2JZ-GTE WS 10.46 131.10
7 VIC Jason Ghiller Ford Falcon XE Ford AU 4.0-litre HP 10.51 132
8 NSW Brett Grabham Nissan Skyline R33 GTS-t Nissan RB26/30 WS 10.557 130.34
9 VIC Dave Hanna Ford Falcon BA XR6 Ford 4.0-litre HP 10.587 130.43
10 WA Jos Oosterwaal Nissan 180X S13 Nissan RB26 PM 10.67 130.80
http://www.hpi.com.au/drag_records.php
The records below are for Japanese cars in Australia running treaded radial tyres. Note that times recorded with methanol or nitro-based fuels are not included.
RWD over 2400cc
Car Engine Capacity Compressor Nitrous Tyres
ET 60ft MPH Track Driver Workshop
1 JZA80 Supra 2JZGTE 2997cc T88H-38GK No BFG 295/50R15
10.04 2.23 150.3 Wllbnk Carlos Novais Millennium Motorsports
2 R33 Skyline GTS25t RB25DET 2498cc ATP600 No M/T 255/50R16
10.12 1.64 136.6 Calder Ryan Quinn ATP/Bresciani
3 1991 Cressida 1JZ-GTE 2491cc garret t51R Yes M/T 255/50R16
10.317 1.596 135.32 WSID Shane Crichton RX Eng./Premier 3
4 JZA80 Supra 2JZGTE 2997cc T88-34D No MT255/50R16
10.419 1.683 138.08 willowbank Mathew LeGrand GTAuto Garage
5 JZA80 Supra 2JZGTE 2997cc T88H-34D Yes BFG Comp TA 275/75R15
10.46 1.66 131.1 WSID Nabil Morcos C&V
6 Mazda MX5 13B 26166cc GT35R No M/T 235/60R15
10.48 1.599 128.49 WSID Lee Docherty NFS Racing
7 R33 Skyline GTS25t RB30/26 2996cc T51RKAibb No M/T 235/60R15
10.557 1.795 130.34 WSID Brett Grabham Steve\'s Automotive/JEM
8 180SX RB26DETT 2597cc GT3540 No M/T 255/50R16
10.67 1.63 130.8 Kwinana Jos Oosterwaal Esso Ord St
9 Z32 300ZX VG30DETT 2994cc S15x2 No BFG Comp TA 275/50R15
10.709 1.672 139 WSID John Penlington Unique Autosports
10 1972 Crown Coupe 1FZ-FE 4497cc GT42 No BFG 275/60R15
10.745 1.879 133.25 AIR Sean Gannon Self
The ET for this car still shocks me - when are they running it again?!?!? Should be almost a whole second quicker.
car was built to use transbrake and nos
this pass was completed with no trans brake just walking it off the line, it didnt see boost till about 70 feet.
carlos has sold the radials and is now running slicks, he has a goal of around 8.7 and high 150 mph trap speed.
i was hoping he would stick with the radials and give theo some one to play with, but he has no passion for the street tyres.
also the car weighed 3600 pounds when he ran 150 mph. and that was with a T88, his current turbo is much larger.
  • 1 month later...
NOS is fine under this category?
10.008et at 139.99 is now the top off the list. i ran that at the sport compact meet last weekend. this was first pass off the trailer with only 23 psi on board and on another pass ran 143.33 mph.
we have to sort the torque convertor out as it doesnt like the extra torque of the 3liter bottom end. so with the boost up i am looking forward to mid nines and around 150 mph
shane
shane
Shane,
Are you looking at getting the car off the line quicker (60 foot) or just getting the converter to lock up better and down the track?
Shane,
at this stage just better down the track, it slipped all weekend at the sport compact meet and ultimately cost us going a nine at that event.
the car has 145 mph in it the way it sits with a fully functioning convertor, so i need to get the convertor to handle what we have now and another 200 hp or more as we are only just at the bottom of the efficiency range of this turbo.
as far as sixty foot goes. on the weekend the 10.00 it 1.68 sixty footed the rest were 2.0's and worse. this was due to not enough gas.
so it needs a bit more gas with this stall speed and a more efficient convertor that will hold the power and it will come together.
at 3500 pounds its never going to look exciting off the line. i would be happy with low 1.6's to high 1.5's
  • 2 months later...
  • 1 month later...
  • 1 year later...
the 10.1 from obehve wasn't on slicks, that time was run on a street legal M/T. yes, its a mickey thompson but its still a full street legal radial :)
the only time obehve has run on full slicks was years ago and he ran a 10.3, with more impovements from atp and danny at initial d racing the car is running better times
with a full street trim setup
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
