  • Replies 162
When you say matrix you mean interpolation.. i.e averaging surrounding cells?
Tim Possingham was/is a wizard with the Microtechs, BUT I do remember he mentioned it can be tuned for the absolute best economy but slight response does suffer. Its just a limitation of the limited load and rpm points. Interpolation can only 'guess' so good.
i ran my PFC with closed loop off for a few months (extensive work on the fuel maps however)
getting around 400k's to tank, sometimes slightly under
with it on it was consistent over 400k's to a tank
so its not the be-all and end all, but it is a good feature to have
if the fuel maps havent been tuned properly (lots of time/labour) then economy will suck without working closed loop.
so does the microtech have closed loop now ?
theres a couple of 33 pfcs on ebay and even a 34 one for 1350$
still cheap in comparison to what else is out there , just dont think about the old price a couple of months ago
That 34 PFC on Ebay is currently on its way to me now :laugh: Paid too much for it but I don't care, at least I was able to get one finally.
Maybe a little clarification might help.
The SAFC/SITC combo sits between the AFM & CAS and the standard ECU. So they modify the signals that the standard ECU receives, tricking it into using the load points on the fuel and ignition maps that give you the desired A/F ratio and ignition timing.
AFM --> SAFC --> standard ECU
CAS --> SITC --> standard ECU
The Jaycar DFA kit achieves the same thing
AFM --> DFA --> standard ECU
The DFA is obviously quite cheap (~$80 plus $70 for the Controller). SAFC’s are readily available, new and used but SITC’s are hard to find as they have been out of production for some time.
The big advantage is you can fit them yourself, set them on zero correction and then drive around just as you would if they weren’t there. Or drive to the dyno for tuning. The SAFC (& DFA) will enable you to stretch the standard AFM as far as it can go before it maxes out. The standard ECU protection stuff (knock and limp home for example) still function.
These are easy to tune, 20 minutes max on a dyno for SAFC/DFA, less than that for the SITC. They have been around for years, so plenty of tuners have experience, even if they don’t, it only takes a few minutes to get familiar
They don’t disable the 180 kph speed limiter, so if you are doing any track work you will need something like a HKS SLD (Speed Limit Defeater/Defender)
The EManage sits between the standard ECU and injectors and the coil ignitors. So it modifies the signals that the standard ECU sends, using the load points on the EManage fuel and ignition maps to give you the desired A/F ratio and ignition timing.
Standard ECU --> EManage --> Injectors
Standard ECU --> Emanage --> Ignitors
The main problems with EManage in the past was its inability to run R33/34 ignitors. A few guys seem to have had success lately so maybe the problem has been overcome. If it has, then they are not a bad choice. No SLD required as the EManage intercepts the speed signal before it gets to the ECU. Since the EManage controls the spark there is no ignition retard on gear changes in autos, so the gear changes are a bit harsher and the gearbox will wear out a little bit faster. The ignition cut on full throttle gear changes seems to still work (limited testing) so it isn't as bad as using an aftermarket ECU with an auto.
The HKS FCon in its various generations is pretty much like an EManage. Except the tuning software is only available to HKS approved (royalty paying) workshops. Last time I checked that was only one in Australia, BD4’s in Sydney
In theory the EManage should enable you to drive the car to the dyno, but this hasn’t been the case in many instances. They are not as popular, so not as much experience out their in tuner land. Be careful of the add ons, the base price may seem attractive, but the options soon add up.
That covers the major piggy backs, ECU observations another day.
:blink: cheers :P
Apexi Power FC has to be the best value for money ECU for Skylines if you can get your hands on one. However it too has limitations due to MAF/AFM prerequesit. A MAP sensor based ECU will handle higher power levels with more accuracy from what i have read.
I personally dont like the idea of an interceptor type aka piggy back systems cause your only fudging the signals that the ECU recieves.
So for stand-alone ECU's my research has lead me to the conclusion that the following would be my order of preference due to cost Vs value:
1. Apexi PFC (Plug & Play) - AFM
2. Haltech E11v2 (Plug & Play) - MAP Sensor
3. EMS 8860 (Wire in) - MAP Sensor
4. Autronic (Plug & Play) - MAP Sensor
5. Motech (Wire in) - MAP Sensor
Cheers
this is inaccurate, covered in the powerfc faq in great detail
d jetro vs l jetro for both powerfc and other mainstream ecu's
you should read it
its not a limitation, in fact map gives you less load points making it having less accuracy
Yea your right with that paul, i heard that MAP sensor based ECU usually have poorer fuel economy compared to AFM based ECU's due to more load points...
Thanks for clearing that up!
Cheers
Fcon pro v for the win!
still am yet to get mine tuned but when i do its going to be an animal and my fuel is going to last a wee bit longer one would think!
will get it over to bd4's soon
you should read it
is this only really comparing power fc d jetro to l jetro tho?
well the topic is around the powerfc as its in the powerfc faq.
but the same principal of ljetro (airflow meter) vs djetro (map sensor) still applies. very interesting read. the only reason you woud have poorer fuel economy would be the tune and the time spent on it.
there is no reason both cannot have the same fuel economy and power from either afm or map sensor. map sensor will probably take longer to tune and run sinle axis style once target boost is reached (generalisation)
There's a guy somewhere down under.
Bikirom- Made for SR's, KA's, VG's etc.
It opens up your stock ECU so you can do anything the computer does.
Currently it doesn't work for the RB's, but it we send him some emails maybe he'll be interested in adapting his product for us.
www.Bikirom.com
no its not but as you said it costs $$$ to tune for cruizing and modify that end of the map which most people dont do , particularly microtech buyers down the bottom end of the scale
and with closed loop the ecu is automatically tuning itself for optimum economy
so its a win situation
defiently not the end of everything , particularly in race type setups where its mostly WOT but its still a good thing to have and if microtechs had it 90% of the cars runing them would get better fuel usage
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
