Hey i thought ill share my story with you guys. I went 2 autobarn on wednesday to purchase my IBC Gizzmo ebc and i thought just to save myself the trouble ill get it done. As i work night shift i thought ill drop it off when they open up. I have had some work done to the car at this autobarn before so i thought well they did a good job with the alarm and sub so they know what they are doing. The guy comes out with me and the usual ask me where i want it mounted i showed him and he said "no prob mate". I told him to take care of my baby and in his words he said "always do".
I went home to get some sleep before work. They phone me up to come pick up my car so all excited i go down to pick it up. Pick it up pay and off i go. I made sure the controller was adjusted all the way down. I take it for a drive and notice that the boost is hitting like 16psi before i crapped myself and lifted my foot because its a stock R33 s2 turbo and are rated 2 13psi from what i know. I get home and open the bonnet to c if a vacuum pipe might have come off. I grab the install/operating guide to check something. When i did this i realised that the have connected the solenoid up wrong. It was connected up as a external wastegate.
I phone them up and tell the umm you guys connected it up wrong. He says no worries bring it back and we'll fix it up. We will only b 10 minutes. One and a half hour later he comes back into the shop and says well they connected it up right now and its still boosting to 20.6psi. When he said that i almost had a heart attack. Then he goes and by the way i have a feul cut at 20.6psi. I almost slapped the s.o.b. He then tells me that the put the compresser on the wastegate through the solenoidand it only moves at 20psi.
I said to him well its a 6pound actuator, so either its connected up wrong again or you farked it up. The y bring the car round to the front and the manager comes out and has a look coz he was on the phone with the guy from Gizzmoi have another look at the manual and see that they connected it up wrong again.
The manager connects it up right this time and i drive home. And will you believe it the turbo was only boosting to 6psi like i said. So i thought it was fixed now and tried adjusting it. This didnt work. I turned the boost all the way up and still nothing. I get home steaming. Phone them up and said to them Listen mate its only boosting 6psi like i said, but now it doesnt want to adjust then i said to him you guys can sort this shit out tommorrow coz i have to got get some sleep coz ive been up all day trying to sort this shit out.
The next day i wake at 4 in the afternoon. A bit calmer now and decide to take another look at the boost control. I phone them up again and ask the manager whether they might have farked up the solenoid when they connected it up wrong. Its possible he says, come down and ill give you another one to try. I go down and grab one, come home and swap them around. And bam. It boosts and adjusts. I take the stuffed one bak and tell them it was the solenoid.
CONCLUSION DRAWN FROM THIS FEATURE OF EVENTS IS FROM NOW ON ILL DO IT MYSELF OR GET A SPECIALIST TO DO IT AND NOT ASSUME THAT A INSTALLER KNOWS WAT HES DOING!!!!!!!
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/
Arhhh gess Franky...
Thats unlucky, not often you get a busted solinoid...
As for the guys at autobarn, I guess they are good at some stuff and not so good at others...
Boost controllers are a pretty easy install, but a busted solinoid would certainlly make one scratch their head...
Yeah keep that turbo on 13psi and she will last for years...
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2858545
So you bought ebc though them right ? You would have been screwed if you bought the unit somewhere else. Im convinced now ill install my ebc myself.
yeah i bought it off them, and yeah man trust me do it yourself.
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2860906
  • 1 month later...
WELL!!!! I was Bayside Performance Services yesterday to fit my new fuel pump. Pump works great fuel problem a thing of the past. But while on the dyno the bloody ebc wouldnt adjust. Could not get higher than 10psi. Manages 145rwkw at 10psi but i want more boost. So off i went to autobarn to tell them about my problem with the ebc, since i got it i have just have problems with it.
I asked for a refund for the ebc and got it, YAY!! Im taking that refund money plus a bit more and buying a GREDDY ebc. So im ripping the GIZZMO ebc out on saterday and taking it back and getting my GREDDY ebc and putting it in. Hopefully it will work. So i will update again on saterday and go for a power run next week on 13psi, 14.5psi and 16psi and see wat i make.
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2947003
you do have an aftermarket dump pipe yes? if not, boost will almost certainly taper off at higher levels.
also, do yourself a favour and f**k the solenoid off altogether.. all it does is get in the way (unless of course this is one of those controllers that stepper the stock solenoid).
Connect your EBC direct between your intercooler piping and wastegate actuator.. the stock solenoid is only useful for a stock setup.
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2947040
Far out... these guys hit 20psi with your standard turbo? Man they're car audio fitters, they should stick to that, i can't belive they're fitting coolers and all these little gizmo's n shit when they don't know.. for all we know they probably shorted out the solenoid causing it to shit itself.. cos they had a 16yr old working on it... not to mention they went for a bust in your car and hit 20psi... bastards!
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2947108
I asked for a refund for the ebc and got it, YAY!! Im taking that refund money plus a bit more and buying a Blitz ebc. So im ripping the GIZZMO ebc out on saterday and taking it back and getting my BLITZ ebc and putting it in. Hopefully it will work. So i will update again on saterday and go for a power run next week on 13psi, 14.5psi and 16psi and see wat i make.
Are sure the Gizzmo was setup right?
Most people don't like them because they simply dont read the manual, its setup is different to most EBC's.
Who tuned it at BPS? Clint?
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2947268
LOL! +100000000 for that one
Its like this. I didnt know bout chris rogers at the time I purchased the bionic wheelchair and the insuro mob insisted i have an alarm. I dutifully rocked up to the barn and shelled out for an alarm and a timer and i am due to have it installed monday.
I met chris at the glen on tuesday night and he offered to try and steal the car. If he could he will then set it up so he cant. So even if it costs me a little more to make it right it will be worth it. Specially after reading bout so many purloined lines. :nyaanyaa:
https://www.sau.com.au/forums/topic/153696-my-ebc-blues/#findComment-2947660
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
