I have the Tomei poncams up for sale at the moment out of my motor. They are the 260 in/ex ones, have only done a few thousand km's in the motor with VERY minimal wear (not even 1%).
They are awesome cams for someone with a GTR that has upgraded small twins (N1's, 2530's etc) and they changed my whole car when installed and created a lot more power through the whole rev range as well (and it stopping the motor from having an asthma attack over 8000rpm).
Looking for $600, pickup from southside. Want these gone today or tomorrow.
https://www.sau.com.au/forums/topic/153827-for-sale-tomei-poncams/
Their just cams.
Why is a hamburger from Macca's called a Big Mac? No..........beats me too.
Tomei just decided to call them poncams and procams for some reason that someone else will tell us maybe. Generally speaking poncams are street and procams are race [but some ppl like to explore the boundaries].
Need to sell these ASAP, will do them for $500 if someone picks them up tomorrow. You cant argue with that price, they are basically brand new! (Didnt even do 5000kms).
Someone must want a set of these for their GTR. They are the best money spent on mods imho after youve done all the obvious stuff (turbos, exhaust, ecu etc).
Edited by Amaru
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
