  • Replies 48
Posted Images
shaun was pretty happy with it being a r33 auto.
obviously the 3k high stall and trans is robbing a bit of its power potential, but all in all im happy.
its very smooth until you here the turbo start whistling.
past that its actually a bit crazy.
Very Nice, was a touch warm today also. Nice cool day and you'll see that 300rwkw. :stupid:
Turns out I have a few questions.....
The 11 power runs? Did Shaun have a fiddle?
Did you get to the bottom of the lack of top end? Suspected torque converter?
not sure i wasnt there.
i think he did two runs one after the other so heat soak and molten tyres would show up.
299.9 then 296.8
its at a constant 24 psi which shaun thinks is a good happy number on shell 98.
the afr is now in the low 11's once boost starts, to redline in a constant line, which is something that John never managed to achieve, and knock is maxing out at 18. but averaging 12.
im not sure if im still missing 50 kws or thats all it has in it with the standard nissan head gasket?
with the 3000rpm high stall it will do a 11, so for a daily driven shopping trolley i might leave it alone for a while and just enjoy it.
cheers
Charge takes only an hour or so. :(
My sister currently has the video camera but I can grab it easily.
RE: The std Nissan gasket. I have no idea.. Its doing pretty damn well. its not o-ring'd I presume?
I've seen cometics around pretty cheap ~$200-$250.
how come you took it to shaun this time and not john?
mainly to get shaun to fine tune my pfc boost ccontroller setup as he has had some really good results with them, and John thinks there crap/doesnt know how to set them up well.
also as my first visit to Boostworx i figured i should go see what all you guys rave about..
top bloke..
top bloke..
fairy muff, so how do u find to pfc boost controller? I'm looking into getting one when i have a bit more money to spend!
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
