NickR33 Posted September 17, 2004 Share Posted September 17, 2004 hmmm... it apparently had the wrong oil filter when it came over from Japan a year ago, so perhaps the damage was already done by the previous owner and it just hung in there long enough for me to break it? I would know if I had starved it of oil because the oil pressure would indicate this? ie driving around with unacceptably low oil pressure. I will definately make sure it is as terminal as suspected before I replace or rebuild but it was diagnosed by 2 very experienced import gurus... so I have been scratching my head... a lot. What is the best method of diagnosis, compression test? leakdown test? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1016926 Share on other sites More sharing options...
predator Posted September 17, 2004 Share Posted September 17, 2004 But new engine blocks don't have any numbers, so there is no "original number" to bring up. Stamping of damaged block numbers on replacement blocks is of course completely legal, otherwise Nissan (and the other manufacturers) would not be able to sell new blank blocks. Call me cynical, but in many cases I don't think they even check too closely.. when i bought a car recently I wrote down the engine number on the reg papers - response: "this is not the engine number on file" .. me: "guess it must have had the engine changed then", them: "err, ok, probably, what is the new engine number?", me gives new engine number (not checked.. might have even got away with rb26xxxxxxxxx), and away we go... good 'ol QLD.. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017173 Share on other sites More sharing options...
Cubes Posted September 17, 2004 Share Posted September 17, 2004 only if there is suspision of the car being ripped off or parts do they check. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017179 Share on other sites More sharing options...
Sydneykid Posted September 17, 2004 Share Posted September 17, 2004 hmmm... it apparently had the wrong oil filter when it came over from Japan a year ago, so perhaps the damage was already done by the previous owner and it just hung in there long enough for me to break it?I would know if I had starved it of oil because the oil pressure would indicate this? ie driving around with unacceptably low oil pressure. I will definately make sure it is as terminal as suspected before I replace or rebuild but it was diagnosed by 2 very experienced import gurus... so I have been scratching my head... a lot. What is the best method of diagnosis, compression test? leakdown test? Wrong oil filter :headspin: , that makes no sense either. If the oil filter leaked you would know about it, oil everywhere. It can only then get blocked, in which case the bypass kicks in and the oil stills flow at normal pressure. It just doesn't get cleaned. You can tell if that's the case by looking inside the cam covers, no filter = dirty scum. Compression test or leak down test tells you nothing about bearing condition. Noise is the best test, main bearings rumble like a heavy train on railway tracks. Big end bearings knock, like someone at the front door. As you free rev the engine the noise dies down and as you back off it comes back louder. Once heard it is unmistakeable. The other test is oil pressure, a good quality gauge will fluctuate with bad big ends. The needle flicks around as the oil pressure jumps as it feeds that crook big end bearing. I suggest you find an old mechanic, he doesn't need to know anything about imports. A big end bearing knock is a big end bearing knock. He will pick it in an instant because it used to happen a lot. A lot of young mechanics have never heard a big end knocking because it doesn't happen very often these days Hope that helps Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017195 Share on other sites More sharing options...
NickR33 Posted September 17, 2004 Share Posted September 17, 2004 Thanks that helps alot... my gf's dad would qualify as an 'old' mechanic lol... maybe time to tow it to his shop... If it does end up being a terminal problem would you go with renowned import specialists and pay the $$$ or go with the family member mechanic who will make the labour costs minimal (is not experienced with modern turbos, though still a good mechanic)? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017317 Share on other sites More sharing options...
Roy Posted September 18, 2004 Share Posted September 18, 2004 You make the decision, talk to a few places you would like see do the work, get a firm price and hold them responsible for their work and the price. An engine rebuild is big money. Some say 2k isnt big money, but thats 2 months work for me. Why is it mechanics refuse to given written quotes, is it a time thing. It would be cool to see a quote that says, Price X in labour, price X in parts so you can compare apples with apples. Worst case scenario you could be wary of the buck fitty quote as you know they havent allowed for certain things, or you can see that they are actually just good operators with low overheads. Hope you get it back on the road soon with as little pain as possible. if your car is relatively std, turbo, injectors ecu and boost, then wrecker motors often come with 3 month warranties etc etc. So thats $2000 (?), sell your head etc for $500-700, sell off the bottom end etc, or just throw new bearings in your RB25. A std nissan engine takes a good flogging if you have the std turbo hanging off it. Talk to ppl you trust and see how you go. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017728 Share on other sites More sharing options...
Cubes Posted September 18, 2004 Share Posted September 18, 2004 Its not just going to cost for the engine rebuild its also going to cost extra for the head welding which could possibly involve R&R of the valves etc. Then there's the ECU. You will need a powerfc. Get the motor in get it tuned. Run the motor in get it tuned again. There's a lot more initial money invloved with the rb30 than simply slapping a set of bearings in the rb25. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017739 Share on other sites More sharing options...
NickR33 Posted September 18, 2004 Share Posted September 18, 2004 yeah I've got quotes on dropping a new (wrecker) engine in and pretty much know how much it will cost. I'm not too stressed about that as I know I can have that work done cheaply and reliably and be back on the road relatively quickly. I just want to weigh that up against going for a rebuild and I really haven't got an solid quotes on that to have made a decision yet. It would be a shame to spend $2xxx on putting it back the way it was...when for a couple of extra grand I could have a relatively stock but tough and tourquey 3L motor? I guess the first decision is whether or not to pay to have the engine stripped to see exactly what the damage is? ... or just out with the old... in with the new... thanks for the comments guys... Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017758 Share on other sites More sharing options...
Roy Posted September 18, 2004 Share Posted September 18, 2004 Its not just going to cost for the engine rebuild its also going to cost extra for the head welding which could possibly involve R&R of the valves etc. Then there's the ECU. You will need a powerfc. Get the motor in get it tuned. Run the motor in get it tuned again. There's a lot more initial money invloved with the rb30 than simply slapping a set of bearings in the rb25. Oops, i wasnt actually referring/comparing to the RB30 :Oops: , just commenting on how to cheaply /sensibly get the car back on the road Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1017808 Share on other sites More sharing options...
Guilt-Toy Posted September 19, 2004 Share Posted September 19, 2004 my mechanic did a RB30DET for someone and invoice cost was $7000 including head. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1018552 Share on other sites More sharing options...
-scooter- Posted September 20, 2004 Share Posted September 20, 2004 Hey guys, just want to ask about height clearence for an R31 import and which sump will fit in aswell?? Dan Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1019214 Share on other sites More sharing options...
tang0 Posted September 20, 2004 Share Posted September 20, 2004 my mechanic did a RB30DET for someone and invoice cost was $7000 including head. cough, splutter !!! $7000 !!! could have bought an rb26 engine for around the 6.5k mark, say $1000 for fitting, and IMHO a much better outcome ... anyway, each to his own Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1019702 Share on other sites More sharing options...
Cubes Posted September 20, 2004 Share Posted September 20, 2004 I don't consider a 2.6ltr second hand motor a much better outcome than a bran spankin' 3ltr. It would be more than $1000 to fit as you first have to remove the old motor then drop the rb26 in. The rebuilt, blueprinted, balanced to race spec (heinz), crack tested (block, rods & crank), forged pistons, multilayer metal headgasket, fitting of the head, cam belt & relocating tensioner set me back $3700. The head reco, port inlet/exhaust, polish exhaust, roughen up inlet & deshroud inlet valves cost ~$1100. Total - $4800 + R&R ($2000) it would come up around 7k. If you think you can buy a RB26DETT and drop it in without bugger all extra expense think again. Expect turbo's to be replaced and a motor that may have been thrashed or a motor that is a little long in the tooth. Eventually needing a rebuild with forged pistons anyhow. People build the 3ltr because they want response, torque and a linear less snappy more tractable hi-po 250-300rwkw+ motor. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1019846 Share on other sites More sharing options...
Bl4cK32 Posted September 20, 2004 Share Posted September 20, 2004 "Can i get an AMEN to that-ah brothers and sis-tahza"...:cooldance....AMEN..HALLELOOYA" Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1020389 Share on other sites More sharing options...
GTR-Ben Posted September 21, 2004 Share Posted September 21, 2004 Yeah stock second hand GTR motor.. dime a dozen here for around $5k... I wouldn't use a second hand one with stock turbos if I was going to drive it seriously. On that note I just painted my engine bay and got a new swaybar that goes around my sump so the RB30 will be dropped in and lowered as much as possible. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1021396 Share on other sites More sharing options...
Guilt-Toy Posted September 21, 2004 Share Posted September 21, 2004 Well I was just thinkin bout the cost of my engine rebuild for RB30DET. It did not cost me anywhere near $7,000. Details... Note that everything is pretty much at trade price & mates rates prices. Block $100 RB30E Re-ring kit + bearings + Genuine nissan head gasket $440 Rebuild engine hone block machine crank pins to over size / clean deck block $330 (Mate) Engine Mount $125 Clutch Plate $105 Exaust Manifold Studs $60 Mate at his own workshop to store car and do work after hours after work or weekend, he supplied everything needed from VCT setup to sending head away to be cleaned and reconditioned with new valve stems / competition fittings for sump for VVT oil drain & Turbo oil drain labour to remove engine dismantle and put all back together was only $2900.00 (+ many nights on the piss) So totally cost me abouts $4000. I think I got a great deal from my mate to do the RB30DET Conversion. He basically chucked in a free head rebuild and used new manifold gaskets.. I also put countless hours of work into it doing it with him.. The outcome was awesome but took us 4 months to do. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1021928 Share on other sites More sharing options...
Cubes Posted September 22, 2004 Share Posted September 22, 2004 Pays to have mates in the trade. 7k I would think would include a set of Forged pistons. RIPS from NZ can ship RB30DET's complete with head for around the 4.5k mark. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1022002 Share on other sites More sharing options...
Guilt-Toy Posted September 22, 2004 Share Posted September 22, 2004 Pays to have mates in the trade. 7k I would think would include a set of Forged pistons. RIPS from NZ can ship RB30DET's complete with head for around the 4.5k mark. No 7k was drive in drive out with a $50 wrecker engine without even cracking it open. (developed a engine knock later) I think he supplier head and turbo and manifolds also. it was a NA VL. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1022008 Share on other sites More sharing options...
Cubes Posted September 22, 2004 Share Posted September 22, 2004 Sh*t. Well he saw him coming.. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1022013 Share on other sites More sharing options...
Guilt-Toy Posted September 22, 2004 Share Posted September 22, 2004 well considering the engine had to be supplied by customer - and thats what he choose to start off with..... The 7k including head manifolds vg30 turbo rb25 wiring harness all vct setups etc etc engine pulled out built up and installed and tuned... dunno bout the intercooler That doesnt sound too bad does it ? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/69/#findComment-1022269 Share on other sites More sharing options...
