has anyone used the arias forged pistons to suit the rb30/25 and know what compresion ratio they give? i rang rocket but they couldnt tell me
I recently bought a set of these pistons.
Pics n details are here from a previous post http://www.skylinesaustralia.com/forums/sh...&postcount=2227
The Arias specs sheet and the factory VL manual specs seems to be different.
Using a stock rb30 na head gasket and stock 25 head it's spose to make 8.6:1 but there are many variables that can change it slightly, eg skimmed head.
But to be sure to get the right comp its best to have your engine measured for a more accurate comp.
What psi does a standard 9:1 rb25det produce when doing a compression test. Would this be the same for a 9:1 rb30det?.
The 26 ARP head stud kit (25 head) arrived today. :headspin:
To double check everything I tried fitting a stud to the block and head. Like others have mentioned in the past, the block needs to be drilled and tapped for the thickers studs. The 25 head holes also need to be made bigger.
I'm not sure on the torque settings for the head studs.
On the back of the ARP box is a listing of torque settings - see attatched pics
PS: It also has this written on the box > "The torque values represented here are intended to be for general information. Not for specific installations!"
is that the actual pistion set they list for the rb30/25 combo or are they just rb30 pistons?
A bit of a wild card here guys , whilst sniffing around at an American site called Nissan Performance Magazine I saw mention of the Nissan VG33 . Its got me thinking that if an RB30 block was bored out and sleeved maybe the bigger bore pistons ie 89mm or whatever could be fitted . The trusty Casio says 3173cc's . I would discover this just after buying pistons ..........................
Actually these things are out here in current Navaras and the bore size is 91.5mm for the std 83mm stroke . Me thinks the humble RB30 Block would not like to be sleeved that far , even for 3353 cc's ........................ But if it could with larger valves in that 26 head ...........................
The yanks are fitting ser 1 VQ45 pistons in the VG33 for approx 3400cc .....
Yep it's a kit includes rings,clips and pins. The pistons are 8601 forged.
The kit suits both 26 and 25 head, the pistons are different from na and turbo Rb30 pistons as seen in the pic.
if you search back through this thread and find my name you will see it discussed numerous times. You need an adapter plate, you need an external pickup and you need to slightly mod the driveshaft side of the sump and change from studs to bolts.... PM if you are serious and ill give the rest of the details....
Fitted up the AP PFC to the R32 RB30DET today.
The base map runs fine providing you don't give it too much.
Knock levels for general driving with a tinny bit of stick is around 8.
Cold starts are good, warm starts require one to play with the accelerator to get it started. :cheers:
Apart from that it definitely runs better and feels much more linear.
my rb30 has rb20 power steer, air con and alternator mounted onto it
the rb30 harmonic balancer didnt line up with all the pullys correctly
we put an rb20 harmonic balancer on it and everything seems to line up fine... :S
what belts should i use? rb30 or rb20... is there any different.. maybe in height due to rb30 block??
I also used the RB20 harmonic balancer.
Use all the RB20DET spec belts.
Did you modify the rb20 powersteer bracket? As you have to.
Unless you use a R31 RB30E bracket.
Probably the least techincal question asked in this thread, but here goes:
I went to fit my RB30DET on the weekend and realised I dont have the engine mount to block bolts.
Does anyone know what width, length and thread pitch these are suppose to be so I can buy some replacements?
More bolts I noticed I was short on were the oil sump to block bolts, does any one know the sizes of these as well?
some very useful information in here guys well done! was just wondering. im going a quicky budget route in my coupe. i have a 26head, larger injectors aftermarket comp , bigger fuel pump etc etc. now i am going for a block. i am really curious if i could get a standard vlt block and slap the head on it with all the other gear. how long do you guys reckon it would last with the right tuning? remembering that i would not run more than 15psi on a gt35 turbo. just to be safe.
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
