why is everyone strung up on the damn strut brace.
Make new ends to offset the bar across the engine to clear the tb.
If your building the engine, you have to cut and weld the engine mounts, so whats hard about making new strut ends at the same time??
possible issue with making the strut brace higher is that i know my strut brace had rubbing marks on it from the std bonnet.. so i know i wouldn't be able to make the strut brace higher ..
saying that i am hoping i wont have an issue with the plazmaman front facing plenum.
yeah my rb30s now fitted. i didnt need to mod the engine mounts. just a slight hammer on one of the under bonnet supports. looks damn sexy.
should have it running on thursday :(
now only if it would stop raining so i could go outside and finishd changeing the fuel pump :)
yeh but how rigid is it going to be ?
I haven't seen any pics either.
See pic below, can't move it forward with the RB25DET head, have to go right back against the firewall.
Useless...
Edited by conan7772
Same as the bar was before, or make it better. :blink:
I havent posted pics, but whats so hard to picture about it??
Your simply offsetting a bar forward, not making great structural changes
This is what came out of the rb20det gearbox + lots and lots of large chunks of teeth, be buggered fishing them out of that stinky oil. :O
Drain Plug
The back of the tooth where it broke
The mesh side of the tooth, looks as if the engaging gear was really digging in and not meshing with the whole tooth. :S
The new box is very very quiet.. Feels quite strange, like a new car. :P
Thats a fatigue failure as you can see from the close curved lines across the broken face and the rough area to the other side of the break.
Starts somewhere about where I've marked as best as I can discern from the photos.
Just couldn't handle no more Cap'n
This pic illustrates the close curved lines a little better.
Sorry Geoff.. I don't follow the Cap'n... :O
Do you mean repeated high load that attempts to and may very well slightly bend the teeth every time?
A little like breaking a coat hanger by bending it repeatedly.
So definitely rb30 related?
Same as the bar was before, or make it better. :D
Can't go forward.
There's nothing between the induction pipe and the bonnet.
Running a bar behind the BOV is too bigger an offset.
It will flex under load i.e USELESS.
What head do you have ?
This is what came out of the rb20det gearbox + lots and lots of large chunks of teeth, be buggered fishing them out of that stinky oil. :D
Drain Plug
The new box is very very quiet.. Feels quite strange, like a new car. :D
Gees you got that in quick !
What did you pay for it ?
Can't go forward.
ive got the 25de head, and you can move it forward.
edit/ im not going to argue about it, but in a 32 it will fit
Edited by Bl4cK32
hey guys...my rb20 just blew up..and im considering doing this conversion as i have heard its a great upgrade....just one question though...i have a rb20det power fc...but if i do this conversion i want to run the rb26 head...will my power fc work with this head (i dont mind if i have to rewire a few things) i already have modded the wiring loom for stock gtr injectors. any help would be good
cheers
It will work fine providing you stick with a single afm.
The only sensor that 'may' not be used is the intake air temp sensor, I am not 100% sure what pin or if it indeed can be used with the rb20det pfc.
SK has said it has or can be done? Not completely sure.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
