hey people about to start building a rb30det unsing s1 33 rb25 head, well proengines in canberra is anywayz, just after some quick advice on the fuel system, will be runiing a link ecu with map sensor and a gt35R hi mount with ext wastegate ect, the motor is been built with a fair bit of power in mind :laugh:
enough for 300+ probably more around the 350 mark,
will a bosch 044 mounted intank do the job? and if so does anyone know of a guide for fitting one cos i know there a fair bit of a biatch been bigger than the 040...
and secondly injectors i've read on this 550cc seem to do the job but would anyone recommend slightly bigger than that for 350kw? i know theres a method to figure it out but i'm not a mechanic harry lol
yeah did the search to begin with, geez i'm not stupid of course i did the search first lol but yeah so much shit comes up when you do and all i basically found was recomending 550 for ppl running 300kw chance are i'll have more than that hopefully (fingers crrroooossssssseeeeeeddddddddd :laugh:)
just thought i'd grab some up to date live info from those in the know
well seeing as all aftermarket injectors are priced the same no matter what size, go for some 700-800cc ones, caus the last thing u'd want is get some 555's and go to tune it and find its running on 100% duty
Have you looked at any other ecu's apart from the link there are better alternatives.. not a real fan of link most of the cars we get in with links leave with a motec lol
just personal opinion i guess
If you go so big be sure to grab a set of twin or quad squirters.
Injectors so large atomize fuel badly resulting in poor fuel economy at low rpm.
that's y i went for the SARD 800cc dual nozzle, should give me enough fueling
i thought the sards are 850cc? or are they 800's?
Weve half fitted the water/methanol injection and got a to4z on the way. haha all these threads and people going on about to4z's and how good they are, plus the figures seem to be there. So hopefully here comes 600bhp with no knock :blink: very very big smiles.
picked up the ecu second hand $180 and it does work lol like the map sensor don't have to stuff around with afm
Nope, you have to stuff around (even more) with a map sensor instead.
:no: cheers :D
Weve half fitted the water/methanol injection and got a to4z on the way. haha all these threads and people going on about to4z's and how good they are, plus the figures seem to be there. So hopefully here comes 600bhp with no knock :angry: very very big smiles.
nah the SARD's are 800's with a twin nozzle
how do u go about traction on the track with that sort of power?
traction...weve only got 500bhp atm and it doesnt exist. starts are shit, but when your moving its fine. Ive found so far that foot control and patience is a big thing. Flat to the floor doesnt always work as well as you might think.
But were still working it all out. It will get better.
Shane are you coming to the next track day on nov 28...cause i will be attending that, so if your there come and have a look at the car, or if your car is ready perhaps i can have a look at that :pirate:
if you don't mind me asking what sort of cost were they??
and where'd ya get them from
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
